cherrybomb
2003 VW Beetle TDI (ALH) with A/T. Bought this as non running car after sitting for 2 years. Prior owner replaced upper and lower O-Rings in the IP (pump), but did not bleed it and lost interest since would not start. Car had 1/2 tank fuel at time. Changed the fuel filter, air filter, oil & Filter, then removed the upper and lower IP case to insure the QA was in the hole on the shaft and resealed the IP. Filled the filter with fuel, and pulled fresh fuel thru the IP using MV. Opened the injector caps and cranked over in brief intervals until fuel and bubbles appeared. Continues to spin over and got fuel as we opened and closed the caps. Car began to run and crank on its own w/o a charger. Over several days we started it and moved around the area w/o any issues. Finally decided to try a longer run and drove it home. Car ran and shifted well; then it started well next morning when we drove it back to shop area. About 1 mile from start, it lost power and quit on a hill, but coasted off roadway. Cycled the ignition switch, it began to start and then ran in a reduced power mode to the shop about 8 miles. We previously added 5 gallons of fresh diesel to the old fuel including some DIesel Power additive prior to beginning the 20 miles round trip. Tried to start this AM after replacing the long injector return hose that appeared to seep fuel. We loosened the caps on injector and strong stream of fuel that went up to hood and on windshield. Did not seem to want to run. Temp was high 40' F and pre-heat symbol came on then went off before we tried to start. Have not verified the air shutoff valve is operating properly or checked the tank pick up. Since car ran well after the initital start and cranked after overnight sit, did not suspect the new fuel filter leaked air. Do not have a VCDS or VAGCOM but plan to. What are recommendations on resolving this no start and run situation?
