benIV
- Joined
- Oct 25, 2009
- Location
- Southeast NC
- TDI
- 2003 PG 5m Jetta GL Sedan, 2003 RS 5m Jetta GLS Wagon (Golf Variant)
My 03 ALH sedan just had a runaway moment I think. I'm almost certain but I've never experienced one before and it was over so quick and it seems fine now so I'm not really sure if it was?
I was at a light and started off a lot faster than I ever normally do. I didn't stomp all the way down on the accelerator but i did go pretty hard on it, more than i ever usually do. When I hit third gear and let off the clutch is when I felt it go. It was like a huge boost so I let off the accelerator but then the engine just didn't stop and climbed real fast. It definitely got to the red line but I turned my attention to getting off the road so I wasn't sure how high it got to. As I pulled off the road and hit the brakes hard I remember seeing the tach dipping down almost to 0 as I came to a quick stop but then as I stopped it started running away again.
I think maybe it dropped because I had it in gear as I was stopping and then as I stopped and shifted to neutral it must've started back up again but I'm not entirely sure.
After coming to a stop I immediately dumped it into 1st and the engine shut down. I'd say at most 15-20 seconds elapsed from the first sign of runaway to shut down. I sat there for a minute and then tried to start it back. It didn't seem to want to start and sounded really weak. I tried once more and it started up with hesitation like it had a weak battery.
I drove it the mile or so home and it ran perfectly fine, through all the gears and all the stopping and starting at various the lights.. I didn't hear or feel anything different as I was driving home but I'm a bit concerned to drive it anymore until I can figure this all out and get it looked at and fix whatever caused this.
Is my engine done?How do I figure out the cause? What might it be? What do I do next?
