andreigbs
Would this work at sealing all the joints that are prone to weep oil and/or pop off? I'm thinking it doesn't hurt plastic, it's flexible to a degree and it should seal up joints perfectly. Anyone have an idea or has tried it? I don't mind being the guinea pig with my PD, because at almost every joint after the turbo I see oily grime accumulated, which means I'm probably losing a little boost in those places as well. If not rubber cement, there is a PVC pipe sealant that works well, is waterproof and also flexible. I'd like to do it but I'd also like some feedback.
