RPM Reading Without Cam Sensor Connected?
ihredneck
Missouri
2000 Jetta, 2006 Jetta
Will a 2006 Jetta TDI BRM 5-speed have RPM's on the tach and/or VCDS if the cam sensor is unplugged?
This is assuming a good engine speed (crank) sensor/wiring.
Dannyboy
Mb
Unplugging the cam will cause a CEL and a tiny loss of power but rpm will still read.
Unplugging crank sensor it won't run or have tach signal
ihredneck
Missouri
That's what I thought as far as the RPM readout.
Got a no start condition, no codes (via VCDS) related to the CPK and reads 275 RPM while cranking. Then when I unplug the cam sensor no RPM via tach or VCDS. I must have a bad crank sensor or wiring, though I'd expect a code to be thrown.
Rx7145
Ohio
2006 Jetta BRM
From what I understand, the computer doesn’t always flag crank sensors. I’ll look at the wiring really carefully.
ihredneck
Missouri
I have already pulled the tape and sheathing from the injector pigtail connector back to the battery box. Some chaffing but no smoking guns.
I will pin-out the wires back to the ECM as well once I figure out how to get the connector off the crank sensor...that thing is buried in there.
Rx7145
Ohio
2006 Jetta BRM
There is a YT video of a guy using a pick to release the lock. To change the sensor you’ll probably need to remove the oil filter assembly.
