RPM dont stop 0
csstevej
north nj
What happens when you connect Vcds with Eng running and compare what Vcds is seeing versus what the guage is reading?
If it’s the same leave it alone , If the two are different pull the cluster , take the front cover off , pull the pointer off and reset it to zero or as close as you can that will make you happy.
