CADtechTDi said:
would the motor mount need to be removed (or half the engine dismantled) to lock the crank/cam shafts, etc.?
You won't have to remove the motor mount, but you will need the crank lock, cam lock pin, and tensioner spanner wrench.
How to: (from memory, thus no pics. If VelociT brings me a car before I skip town, I'll take some.)
Remove the upper intake pipe and upper TB cover to gain access to the belt (already pictured here)
Rotate the motor to TDC.
Lift and safely support the front right corner of the car.
Disconnect the lower intake pipe (turbo to intercooler) at the intercooler. Use some bailing wire to secure it to the control arm or sway bar. This will hold it back out of the way so it's not flopping in your way the whole time. You can also increase access down by the crankshaft pulley by cutting the steering wheel all the way to the right.
Wind the serp belt tensioner back and remove the serp belt.
Remove the harmonic damper/serp drive pulley.
You might have to remove the lower timing guard, but I don't think so.
Recheck that you're still at TDC.
Insert the crank lock.
Loosen the tensioner nut and wind the tensioner back. *your TB should have some slack now.
Insert the cam lock.
Loosen the three bolts securing the cam sprocket to the cam hub.
Tension the belt and snug then tensioner nut. (yeah, I know, it says always replace in the Bentley. Really though, it's the same design as an ALH, which is a reusable nut.)
Tighten the three cam sprocket bolts.
Remove the locks.
Rotate the crank 2X.
Make sure the CAM lock will go back in. (it might take some struggling...1 cam degree is 2 crank degrees.) You're just trying to verify that the hub isn't moving in relation to the sprocket and you won't smack a valve when you start the thing.
Remove the locks.
Reinstall:
Serp pulley, serp belt, side skirt. belly pan, lower intake pipe, upper timing cover, upper intake pipe,
No motor mount removal required.
