Gothmolly
So I'm trying to replace a failed IP, and I need to bring the motor to TDC. Following the advice of some, I jacked the car, put it in 5th, and started rotating the passenger wheel. I got about 1/8 of a rotation and then bam, the thing stopped - it got to the point where the force I was exerting was twisting the whole motor in its mounts, but the thing refused to turn. I even pulled the GPs.
What's the trick for manually rotating to TDC ?
