Transmission: Putting Everything Back Together
Reinstalled the dogbone pendulum mount. Tightened the two new stretch bolts that go into the sub-frame with a 13-mm socket to 20 Nm (15 ft-lb) plus an additional ¼ turn, and tightened the two new stretch bolts that go into the transmission with a 16-mm socket to 40 Nm (30 ft-lb) plus an additional ¼ turn.
Refilled the transmission with 2 liters of Lubromoly Gear Oil, and reinstalled the fill hole bolt with a 17-mm Allen bit until tight.
Reinstalled the white plastic passenger’s side CV joint heat shield by tightening the two bolts with a 16-mm socket to 35 Nm (26 ft-lb).
Carefully reinstalled the green rubber boot of the slave cylinder into the top of the transmission onto the clutch fork; making sure it was straight. Tightened the two bolts with a 13-mm socket to 25 Nm (18 ft-lb).
Reinstalled the black transmission-to-frame support bar by tightening the two bolts and nut with a 13-mm socket and wrench to 25 Nm (18 ft-lb).
Slid the starter motor into place onto the transmission, and tightened the two combination bolts with an 11/16-inch, long impact socket to 65 Nm (48 ft-lb).
Placed all of the cables above the starter motor and transmission back into the plastic cable bracket.
Reconnected the starter motor’s negative terminal connector by pushing home the spring connectors.
Placed the starter motor’s positive terminal wire onto the terminal bolt, and reinstalled the nut with a 13-mm socket to 13 Nm (10 ft-lb). Reinstalled the plastic terminal cap.
Reinstalled the large connector into the top of the cable bracket.
Placed the cable bracket onto the upper starter motor combination bolt, and tightened the nut with a 13-mm socket until secure. Reinstalled the power steering bracket onto the lower starter motor combination bolt, and tightened the nut with a 13-mm socket until secure.
Reinstalled the two power steering line clamps (front and rear) with a 13-mm socket until tight.
Underneath the car, reinstalled the connector for the vehicle speed sensor at the rear of the transmission.
Lightly lubricated the white plastic sleeves of the gate selector cable shaft with molybdenum grease, and inserted them. Reinstalled the gate selector cable shaft into place.
Reinstalled the black shifter cable bracket on top of the transmission by tightening the three bolts with a 13-mm socket to 25 Nm (18 ft-lb).
Placed the power steering hose back onto its clip on top of the black shifter cable bracket.
Reinstalled the connector for the reverse light indicator.
Placed the short shifter onto the spline, while aligning the thicker spot on the spline with the appropriate slot on the short shift bracket. Reinstalled the nut and washer with a 13-mm socket to 25 Nm (18 ft-lb).
Reinstalled the circlip onto the gate selector cable shaft, making sure it locked into place.
Reinstalled the air box, and tightened the rear bolt with a 10-mm socket until secure. Reconnected the rear vacuum line.
Reinstalled the accordion air intake hose to the air box with a T-bolt clamp, which was tightened with a 7/16-inch socket.
Reconnected the MAF air sensor connector.
Reinstalled the battery platform into the engine bay, tightening the four bolts with a 10-mm socket until secured.
Placed the battery on top of the platform, ensuring that the bottom rear lip of the battery gets tucked into the correct position within the platform. Not doing so will cause the battery to be elevated and the cable tray to not sit flush (guess how I know this?). Reinstalled the front battery bracket and tightened the bolt with a 13-mm socket to 25 Nm (18 ft-lb).
Reinstalled the TDI heater bracket onto the battery platform using a bolt, two washers, and a nylon nut with a 7/16-inch socket and wrench until tight.
Reconnected the air box to the battery platform with a 10-mm socket until tight.
Reinstalled the small plastic piece that hold the rear cables up against the battery platform, and reinstalled cable tray holder on top of the battery. Reconnected the cable tray onto this holder.
Reinstalled the negative and positive battery terminals with a 10-mm socket until tight.
Reinstalled the battery cover and driver’s side light cover with two Philips screws.
Reinstalled the driver’s side plastic fender well and splash guard by tightening the 12 screws with a Torx-25 screwdriver.
Reinstalled the driver’s and passenger’s side engine splash guards by tightening the star washers with the long screwdriver.
Reinstalled the front wheels, lowered the car, and tightened the lug bolts to 120 Nm (89 ft-lb).
Before starting the car, I engaged all of the gears, including reverse, and pressed the clutch to feel if things seemed normal.
Started the car in neutral and looked for leaks from the oil pan, rear main seal via the transmission, and drive flange seals; I did not notice any leaks. Test drove the car for about 3 miles. So far, no oil leaks from the new rear main seal or oil pan reinstallation. The clutch chattered a little bit taking off in first, but I guess that's not too surprising during the initial break-in period. The break-in period is stated to be 500 miles.
At this point, I parked the car and went off to Deutschland for a week for my work. Hadn’t been back there for almost two years, and I miss living there a lot (See Post Nr. 1).
I returned from Deutschland and checked under the car for any oil leaks, and there were none. So, I reinstalled the Panzer skid plate and bumper skirting. Now I’m on vacation for a week and a half, doing things around home (like writing this), and I haven’t had a chance or reason to drive around. Oh, well!
