rocketeer928
Been having a little issue with my fuel lift pump the last couple of weeks. When the fuel tank got to about half full there was this constant pumping/sucking noise in the tank, and not just the usual whoosh I hear when initially turning the ignition to the "ON" position just before firing the TDI up. Even my wife noticed the noise. Then I saw that the little fuel gauge that I placed on the line under the hood prior to the filter was reading null and there were a lot of bubbles in the fuel line.
Uh-oh!!! I figured the lift pump was not working for some reason and the 11-mm fuel pump was the only component drawing fuel. When my car had a bit of trouble starting cold, I really new something was up. Parked the car for a week until I had time to look into the issue.
My first thought was that one of the hoses in the lift pump from my doing the Left Coast Resident Modification either worked itself loose or were cracked. Today, I was finally able to take the lift pump out. All the hoses were fine, but then I found the culprit! The yellow wire feeding electric to the actual pumping mechanism had worked itself loose and disconnected. Tightened that up, reinstalled, and all is good again! Glad I didn't have to buy a new lift pump (bummer for IBW).
Took the TDI out for a spirited drive afterwards to force the soot buildup in the turbo out. I'm sure the folks behind me always love it when I do that, but it's gotta be done for the health of my turbo and to have a bit of fun.
