I got mine from raybuck, and finally (about a year later I think) opened up the box. I'm glacial too. State inspection failed so have to fix the rocker now.
Part is NOT primed, but is at least coated with something since it didn't rust in the box. Panel seems fine, if you can find one in pre-primed black, thats the better choice.
(Even though the picture from raybuck shows black, mine was not black)
Front end of the rocker is formed with the fender tab (see pic) so not sure that one needs an "end cap". Guessing there might be someone making an end cap repair part for mild rust repairs.
I'm going to cut out the rust , cut off what I need (at $56, it wasn't worth my time to find a shorter "repair" part). rattle spray primer and all the other stuff.
I have a mig welder that will do the job. Trick is drill small holes in the repair panel where you want to weld to the body (not into the body!!). This makes a "spot" style weld, without having a spot welder.
Have to fix it so, will follow up with some pics and info to share as I work through it.
++Subscribed
