panther_v
Please PM LokiwolfLooking for this update...can someone message me a link where I can dwload?
Thanks,
Chris
Thanks,
Chris
Sorry Chris! I got your message, but my Inbox has been slammed with questions and requests. I'll PM you shortly.Looking for this update...can someone message me a link where I can dwload?
Thanks,
Chris
Seems to be a few flaky ones, I would say about 10 so far that the 24Hr setting helps with.FWIW, mine did fine on the first try in 12 hour mode . . .
- Tim
Didn't even realize as my clock is already in 24hr mode.Seems to be a few flaky ones, I would say about 10 so far that the 24Hr setting helps with.
I know 7994 is different than 7870, supposedly to improve indexing. The Data doesn't change in location, just how the 510 looks for it.Thanks to Loki, I successfully updated to the new version.
I'm curious on a few things though:
1. 7994 (V5.2) is a reorganized version of 7870 (V5), but both has same content. How about 7963? Does this version have the same structure as 7870 or the database structure of reorganized 7994 (ie improved access...)?
2. If I decided to move back to V5.2, will the system allow me to install an older version? or it is not backward compatible?
In case you missed what WHMjr saidAgain, I will say this one more time. If you have 4366 loaded and your unit continues to reboot/hangup, then you have a faulty unit.
To be fair, I think he knows he has a "bad" unit.Thanks, but I've complained a bunch, including with VW Consumer Relations. Thus far, I've found that VW and the dealer frankly don't seem to give a hoot about their customers in any possible way.
Understood - my point being that is not a 'hard' requirement, and we don't know how it is related, other than apparently having been seen 10 times or so . . .Seems to be a few flaky ones, I would say about 10 so far that the 24Hr setting helps with.
Agreed!Understood - my point being that is not a 'hard' requirement, and we don't know how it is related, other than apparently having been seen 10 times or so . . .
- Tim
WHMJr and I have taken the conversation over to PM, he has apologized to me, and I to him for the direction the posts went. We are done discussing that. I read EVERY one of his posts more than once. I know exactly what he said and didn't say. We have moved on, how about you?In case you missed what WHMjr said To be fair, I think he knows he has a "bad" unit.
I'm glad you listed the lunch list of "updates and/or fixes" VW has tried to distro, but really? Do we need a half dozen different head units on the street that all require different versions of disc's to fix a problem? And it depends on if your unit was installed between 2pm and 8:45 pm on the 2nd Tuesday of the odd month, the disc you try to load might brick it (if it's the wrong disc)? That's pretty much what it's come to IMO. At least VW sent out a disc so I will give them hats off for that. I've had my 2011 Town&Country since new and Chrysler hasn't sent me diddly squat (well, they do send me notices to come in and get my tranny flashed every once in awhile) But I think some of us look at these updates as a mine field and take a chance to fix/update something that should have been addressed LONG LONG ago.
Thanks for your list but as far as the gripping goes, did you REALLY think it wouldn't happen? Just sayin
Oh, and by the way.. I did do my update. Took over 2 hours. Don't have the disk with me so not sure what "version" it was or what radio RNS510 is in my car. All I know is it's still stalls if you press too many buttons at once. It's like yelling squirrel while a hunter is trying to order from McDonald drive through.
Hmm... i am installing 5.2 as we speak just to see it the topographic function really works...I did notice the book that came with the CD talked about having topographic info instead of weather but nothing seemed to change on the unit itself.
Called the help number at VW and they didn't know anything about it but it was a call center.......they're always the last to know.
Tim
crystal!Clear as mud?
Which update did you install? Map or firmware?Ran the update last week and it took about 3+ hrs. I had one of the early 2013s with the 510. There really hasn't been any real change in the speed.
Tim
He did the V5.2M(7994) Map update from VW.Which update did you install? Map or firmware?
Eric
Yeah, mine did that on V5.0(7870) and it does it on V6(7963), but it appears to do it less. I did 7963 and 4366 at the same time, so hard to seperate.crystal!
i love the auto zoom feature on the map. but i noticed since the update, it disengaged itself twice already.
not a big deal, just an observation...
Never said it was a hard requirement. That's why I listed it as a troubleshooting tip.Understood - my point being that is not a 'hard' requirement, and we don't know how it is related, other than apparently having been seen 10 times or so . . .
- Tim
$10 says the dealer doesn't even know how to check what version the software is....or what firmware even is in general.I sent them an email last week about how slow the RNS510 is. I'm surprised to receive a call from them today. It's just a courtesy call and they want to make sure that my problem is addressed.
They're asking me to bring my car to the dealer so there is a documentation of the problem. They're also sending my complaint to their internal departments for further investigation.
My question is...
I installed the goodies from Loki. How is that going to affect me if I bring the car back and they finding out the s/w and map version are not what they're expecting?
Thanks in advance.
Definitely worth the effort! New roads have been updated, and many points of interest have been added and others deleted.Thank you for your due diligence in compiling this information. Do you think it is worth the time and expense to purchase the 7963 Map data? Thanks again for your time.
Yes I have noticed! Because of my Job, my Contact list is ridiculously long, and I don't fight with it as much as I used to.Have you all tried voice control on the RNS510? I noticed after the 4366 upgrade, it recognizes the names in phone book much better than the old version.
Eject the disc, 3 finger it twice then put the disc in. If it doesn't work that time, load the disc from VW.I have to agree, 4366 has helped allot... Thanks LokiWolf.
As warned, the V6 maps (i think) are failing to load. Not sure since when I hit the eject button, I get the warning about ejecting but it shows that the maps are still downloading and the gas gauge keeps running, gets to the end, and starts over. I'm about 5hrs in with a few car turn-offs and starts. My commute is 1 1/2hrs so the process has had time.
Should I let it keep going or eject and take my lumps? Would the 3 finger reboot be worth a try?
Also... I have Kessy and I don't know how to keep the download going with the engine off. I can start the radio with the car off and it continues for a few minutes then shuts off...
Eric
You can PM Lokiwolf and he'll send the firmware and VIM update and map links.I might have missed it when scrolling through everything. I want to know how to get VIM so my son can watch things on trips or long rides. Thanks for the help!
Sent from my iPhone using Tapatalk - now Free
