@n0th3r_b33r
Huge props to LokiWolf for the knowledge and help to a WV newb such as myself.
Thank you sir for you contribution to the community!
Havard,Hi.
I want to activate video in Motion in my car.
does anyone have a link to iso file that works on the 2014 Transporter?
rns510
HW version H20
SW version 6270
Map version hdd 8048
Thanks, Håvard
The VIM file works on all of the RNS-510's if I remember correctly. I read that on the wiki with all of the versions listed I think.
I would very much appreciate a like to the new maps! Cheers M8 and keep up the brilliant work. Steen. Edit: PM sent as well. CheersWelcome to the party. V7 has been available to purchase for almost a month. Why purchase it when you can download it?
It is pointless to do 5.2. PM me.Thanks to Loki for my last update.
I am currently on FW 4366 and maps 7963.
I got the update DVD in the mail and have a question.
Maps 7963 is V6, and the update DVD is v5.2 and the OP mentions there is some improvements in v5.2 with the way the data is organized.
Is there any benefit going from V6 down to v5.2? Or is V7 better than both?
I don't often even use the navigation as its easier to use a cell phone for short trips where you can use voice commands.
Thanks. Most of us here are in North America, hence the focus there. If you are looking for the most recent firmware, and fixes for the EU RNS510, I suggest you check out VWNavi.Newest maps v10 western europe available ;-)
No, Navteq only provides the Map updates. Continental via VW are the responsible parties for the Firmware.Ok so from the Navteq website it only talks about the maps update, can the SW be updated still with the same disc they send?
Claus, check out VWNAVI.com, they will have everything you need for the Euro radios. You will most likely need to purchase the maps, but there are links to the firmware.Hi !
I just bought a car with RNS-510 / Columbus but the firmware and maps are some years old.
Do you know where I can find the new up-to-date firmware ?
Where can I find maps v10 western europe ?
Regards
Claus
4369 - 2014's come with this. The Unit is a K Unit. There are small hardware changes within the unit, including a different drive controller and an IDE SSD. It is faster than a J Unit, but that is due to the SSD not the Firmware difference. It will ONLY work on a K Unit, as far as known at this point. Nobody has tried, because there is a High likely hood it will brick a J unit or older.
Hmmm. Longhorn's unit seems to contradict Loki's original statement about 4369. So, is it possible to update a "J" unit to 4369, after all?Hi Lokiwolf, I have a Rev J unit with 4369 firmware. Is it possible to upgrade to 5374?
There are a FEW J units that came with the SSD, and therefore have 4369. Think of 4369 as the new base firmware for the SSD units. Some K units came with the Non-SSD, and therefore have 4366 also. If you have anything less than 4369, you cannot go to 4369. The newest firmware you can to is 4366. It will most likely be the last firmware of that generation. Just like 1140 is the highest the older units can go to.Hmmm. Longhorn's unit seems to contradict Loki's original statement about 4369. So, is it possible to update a "J" unit to 4369, after all?
And, if so, would it matter if it was originally an "E" unit that was upgraded to "J" using firmware 4366? (I have always assumed that E-J units were basically all the same, with the FW being the designating factor.)
As clear as an azure sky of deepest summer.
Thanks!
I assume we can still upgrade the maps, regardless of FW or HW designation?
Press and hold the setup button until you see an option for Device Info.How can I check what HW version I have(says H21)?
Also how to check if I have HDD vs SSD?
this is from a 2014 TDI SEL
thanks
