DieselDave2
Which scanner will run the fuel to prime the high pressure injector pump that doesn't cost a fortune for my 2015 VW Jetta W a 2.0L Turbo diesel
Ross-tech vcds. It costs $199 and will do that and much more.Which scanner will run the fuel to prime the high pressure injector pump that doesn't cost a fortune for my 2015 VW Jetta W a 2.0L Turbo diesel
Thank you. Will this tool also reset my car after an oil change?
Yes on my Wife's 2013 Golf R I reset the service light after oil changes. I have VCDS Hex ComThank you. Will this tool also reset my car after an oil change?
