Right Scanner
DieselDave2
2015 VW Jetta 2.0 Diesel TDI
Which scanner will run the fuel to prime the high pressure injector pump that doesn't cost a fortune for my 2015 VW Jetta W a 2.0L Turbo diesel
jef@rosstech
Associate Ross-Tech Vendor , w/Business number
knoxville
2004 Dog hauling, wood towing, pinball stashing Jetta wagon
We even have a video on this topic:
Regards.
Lightflyer1
Round Rock, Texas
2015 Beetle tdi dsg
A jumper can be made to run the fuel pump from the fuse box if needed IIRC. Discussed in some threads here. But VCDS is the tool of tools when working on these cars. Mine has been very helpful to myself and some others that needed codes read.
Lightflyer1
Round Rock, Texas
2015 Beetle tdi dsg
More than likely but you may also be able to do it using the car controls too. Read the manual and see what it says. Different cars have different options enabled.
rhinorear
Lost Causes NM
2014 JSW
Thank you. Will this tool also reset my car after an oil change?
I don't know how different a 2014 JSW and a 2015 Jetta are but on my 2014 I reset that through the instrument cluster. Instructions in the owners manual
Easy peasy
On the cheaper end is OBDeleven app and dongle
