I just finished installing my MFA cluster yesterday.
If you have your MFA cluster converted by
Dewhite2485@hotmail.com, the intallation and conversion process is much simplified.
Basically, you need an MFA cluster from a 96 or 97 car, the MFA wiper stalk, and you need to create a harness to go from the MFA stalk to the fuse block.
If you do that, you will have MPG, time, trip time, and trip length.
Note, for wagon owners, you can use the MFA stalk from a sedan (easier to find), its just that you will have to either transfer the arm over to your switch, or trim a little nub off the sedan switch that prevents the arm from closing the contacts for the rear wiper.
Installing the oil temp sensor was very straight forward, remove the plug with a 5mm hex, and install the temp sensor. The connector for the sensor is just sitting there waiting to install on the sonsor.
Also, the plastic connectors were not available at my local vw store (backordered), so I manufactured the MFA harness from a 4-wire connector I had lying around - the one that goes to the trunk release on sedan models. You have to trim off one of the retainer "arms", but after that it fits in the fuse block perfectly.
