eugene89us
I wanted to share my experience with LasFit H7 G2 Pro Series. I saw a video on YouTube about a year ago about LasFit G2 H7 low beam light bulb that fits plug and play for our NMS Passat. The same reviewer then also reviewed the prototype of V2 of the same bulb with improvements over V1. I contacted the company a year ago, asking when V2 will become available as I decided to wait for it instead of settling on V1 version that didn't have improvements the new version had. Finally, as of August 2020, they finally released production V2. The price of $99 is mighty steep, but for ease of installation and promise of improved lighting, I decided to try it.
Now, I would suggest getting it from Amazon, since it is Prime shipped and includes a $5 discount. Anyhow, wanted to share my experience.
I received the shipment yesterday. The original halogen bulbs are like driving at night with a candle. Terrible. Changing entire housing runs north of $500 for a decent Chinese upgrade. I felt an LED bulb specifically designed to plug and play without adapters would be least invasive if it works well.
I am happy to report I installed it today and the difference is literally night and day. The cut off lines for low beam are almost identical to the halogens, but the brightness far surpasses halogens. White light is also very good looking. I drove a bit this evening, did not get flashed at all. When turning on high beams, you can barely tell halogen high beams are on, since LED low beams are so bright. I am hopeful this company produces high beam replacement also, they say on their Q&A that they are working on one. See photos below and make your own judgment. I have 45 days for free returns and a year of warranty, so I will update this thread with additional information if something new comes up.
The bulbs basically screw in without any extra adapters. They contain a small fan to provide active cooling in addition to passive fins it already has. It was a hard decision between these and deautokey ones that many suggested here, but most of my online research suggested having additional active cooling is a sign of better LED replacement instead of relying on passive only. At someone's recommendation for our cars I read online, I purchased a 75mm dome shaped headlight cover. Although OE cover will fit back with these new bulbs, it will probably leave a 1/8 inch space betwen itself and the fan. Domed covers give a few extra inches of space for cooling behind the fan while completely sealing the unit to prevent dust. As much dust as the outside of the OE cover accumulated over last 6 years, I would not run the headlight without dust cover, even if it means these lights will not last as long. But with domed extensions, I think it will be a good upgrade without compromises. Keeps the housing clear of dust while giving more space for circulation. Here is the link to the covers, I got them on Amazon.
Plug and Play H7 LED Bulb w/Retainer Adapter for Volkswagen Golf Passat GTI Tiguan Mercedes-Benz Metris Pro G2 | 2 Bulbs
LASFIT Pro Series G2 H7 LED bulb is exclusively designed for Volkswagen Passat B7, Golf, GTI MK7, Tiguan and Mercedes-Benz Metris, just for plug and play installation. Install within 10 minutes, needn't any retainer or extra part, no error code, no flickering, easily upgrade and change, click to...
www.lasfit.com
(2pcs/set) 75mm Universal Car light Seal Cap Dust Cover
Rubber housing seal cap, which is used for changing the original headlight bulb seal cap. It is made from durable rubber material, would not harden or crack over time through from hot or cold temperature changes.
www.auxbeam.com
