The OP has a 2014. I wonder if there were some ECU changes with 2015 (given the different motor) that aren't accounted for by LasFit coding resulting in error codes for 2015s but not for 2012-14.Well now I'm confused. The OP says the low beams throw no errors, but you say they do.
No it should be good, I can say for the 13' passat the owner before me had Lastfit Low beam installed and never throw a code. But also I think he bend the tabs in the head lights as it locks in very snug.Well darn, I ordered them last week for my '15. My headlights seem unusually bad for these cars and finally got fed up driving home.
Unless the light itself is faulty it shouldn't cause any damage to my car correct?
Ha....not headlight related. But, I "upgraded" my reverse bulbs to DeAuto reverse LEDs. Occasionally upon srart up iget the bulb error and a message to check (L) rear backup bulb. Goes away when I put it reverse...and bulb works. Everything,and I mean EVERYTHING I've ordered from them came with issues like this. Don't work at all as advertised....Here is what happens on my vehicle. This is not all the time, only when I start my car. Mind you the parking brake is on when I start, and this seems to happen only during the day when the DRL's may run, but not the normal low beams. The error / issue goes away if I turn the headlights to ON instead of AUTO. Otherwise, seems to work fine so far.
-Anthony
Thanks for the feedback. Got them from Amazon, directly from them or ... ?No errors on my 2015 so far and I love these headlights. The pictures really don't do them justice. If you told me they were OEM I'd believe it. The cutoff is pretty crisp and the spread is great. No adjustment needed.
If you're on the fence about getting these I'd get them. It isn't even looks- it's safety. So many times I'd driven down a pitch black road and someone wearing all dark clothing in the road I could barely see. Maybe it was just my bulbs but my '89 jeep had better headlights.
Thank you very much for the detailed report back. I have a 2015 SE. Would the rear turn signal be also yellow color like in the video?I have an update on installing LasFit rear turn signal/brake light/tail light LED bulb. There were two versions I tested - the "fancier" version with canbus actually threw a bulb out error. However, a simpler version without canbus worked like a charm. I am not sure why that is the case, but that is the beauty of our German cars - they want to be picky with headlights and high beams, but the tail light decides that it would rather have a simple LED. Here is a video, left side has LED light and right side has halogen. Please be mindful that fine flickering you see if due to camera effect as with most LEDs, there is no flicker to the naked eye in either tai-light or brake/turn signal modes.
The LasFit site had a promo for a few bucks off and free shipping. It was about 15 or so less than Amazon when I ordered the low beams a few weeks agoThinking about getting the LasFit H7 G2 Pro directly from the vendor as opposed to going through a middle-man (Amazon).
Thoughts on this?
Ok, good deal. Thanks for the update. I will check it out. Somehow I feel to order directly might increase my likelihood of getting the latest version.The LasFit site had a promo for a few bucks off and free shipping. It was about 15 or so less than Amazon when I ordered the low beams a few weeks ago
Without a doubt would recommend getting the high and low beam lights directly from them. It is also much easier to obtain warranty replacement if that becomes necessary. Just keep a copy of your email, since they cross reference order number.Thinking about getting the LasFit H7 G2 Pro directly from the vendor as opposed to going through a middle-man (Amazon).
Thoughts on this?
