Reverse Lights
MVJetta
Reno, NV
2012 Jetta
you can use 2396 or a krypton 3497 bulb. These are used if you are using non LED bulbs. I use the 2396 which is brighter but may opt to use a 3497 in the near future.
MVJetta
Reno, NV
2012 Jetta
The 2396 bulbs do put out a good amount of light. I was somewhat in awe by how much brighter they were from the 7506 stock bulbs. I just ordered a 10 pack of sylvania 3497 that I will be installing this weekend.
You need to physically remove the two nuts that hold the housing in to install the new bulbs.
MVJetta
Reno, NV
2012 Jetta
Let me know . I don't get my bulbs in till tomorrow. I'll also drop a pair in my DRL housing too. I had 2396 in the DRL housing but they only lasted 3 1/2 months so I put the standard 7506 back in.
MVJetta
Reno, NV
2012 Jetta
I just installed the 3497 on one side of the DRL , Rear Turn Signal and Reverse Light. I'll have to see if there is a difference. It'll have to wait till tonight since there is still light out.
The city light is a W5W or 2825.
