reverse gear hesitates 5-10 seconds then clunks into gear
highmileage
new jersey
2005 passat bhw tdi (presently), 2001 jetta alh tdi (previously), 1998 jetta ahu tdi (previously)
2005 passat tdi, gmr auto trans-216,532 miles. torque converter replaced at 135,000. filter and fluid changed at 60 k intervals. all forward gears are fine. when going from park to reverse with foot on brake loud clunk and car vibrates, without foot on brake lesser clunk with engagement and no vibration, with car rolling backwards, then engagement is comparatively smooth with no vibration and slight sound. once in reverse operates normally. scan with vcds shows no codes. thanks in advance for any ideas.
thundershorts
west chester pa
2015 passat tdi sel premium 2015 golf s tdi gls tdi b5.5, 2002 eurovan,Peugeot 505 td,Citroen cx25 prestige
You have a pressure loss in the reverse circuit. You could look at a flow diagram but that really won't help you, too many possibilities. I'm afraid that you are looking at an overhaul.
highmileage
new jersey
Thank you for responding.
highmileage
new jersey
Would anyone have an etimate of parts, difficulty, and/or costs to above overhaul? Thanks.
afarfalla
sugar land tx
05 Passat sedan and 05 wagen
basic rebuild 2k, upgrade rebuild 3k, rebuild complete 5k installed. auto to manual from Frans 2.5k, installed 4k, some margin of error
thundershorts
west chester pa
the zf master overhaul kit is almost 1000, plus any hard parts. you will find that the best deal would be to send it to eriksson enterprises old saybrook conn. they are a zf distributer and are not only reasonable but competent. many here can vouch for that.
thundershorts
west chester pa
Eriksson may still have a pickup and return service for you as well. Call them.
highmileage
new jersey
Sorry for delayed thank yous. Have been very busy and just got back to site. Thank you gentlemen for your responses.
50harleyrider
charleston,wv
2005 B5.5 TDI/geared BSM, BV43A turbo,stage 2 TDTUNING. 2005 5sp manual passat tdi stage 2 tdtuning,BSM delete. 2015 Passat TDI 6sp manual.
I bought a rebuilt tc from Eriksson and it was fine. They are a very professional outfit and let us know if they give you a quote for the rbuild including tc and what the shipping costs are. It's a heavy tranny so probably won't be cheap but Eriksson has an agreement with either Fedex or UPS and you'll probably have to strap on a half pallet and they'll come fetch it.
thundershorts
west chester pa
Did you check if they still have pickup and delivery service in NJ?
