TeDeEye1
Since WV has to detune the TDI to meet our current emission standards do we get a retune when ULSD becomes the norm?
So ULSD will be a good thing?dieseldorf said:reduced fuel economy
poor performance
rough running
hard starting
etc.
About 18 months ago I started a thread for discussion based on the hypothesis that Arco ULSD had a lower BTU content and cost TDI drivers 1-1.5 mpg. I was basing that on a series of 16 tankfuls, half Arco and half not, during the period from late March to early May 2004. (I should also note that I was getting poor fuel economy from all sources during that period.)eetsoot said:We in Cal have had ulsd for a few years now. I find that with it you take a slight hit in economy, 2-3 mpg and a slight hit in power. Also the fuel foams up more so topping off your tank to the rim takes longer with it. These opinions are based on Arco (BP) diesel.
Tornado, do you add additives? I think additives may make the mileage/performance difference between ULSD and regular D#2 trivial. For example, my experience with BurkeOil ULSD is that it causes 2-3 mpg decrease in the mileage and slight improvement in performance (my car becomes more responsive with ULSD). I do not use any additives.TornadoRed said:About 18 months ago I started a thread for discussion based on the hypothesis that Arco ULSD had a lower BTU content and cost TDI drivers 1-1.5 mpg. I was basing that on a series of 16 tankfuls, half Arco and half not, during the period from late March to early May 2004. (I should also note that I was getting poor fuel economy from all sources during that period.)
I've driven a lot of miles since then, nearly 100k miles. And because Arco has rarely had the best prices, I haven't used it very often. But when I have used it, my fuel economy did not vary by any measurable amount from the non-Arco fuels.
Since mid-October til about 2 weeks ago, I was using one independent station that had extremely attractive prices -- typically 30 cents/gallon less than major brand stations only a couple miles away, and lower than every other station in the county. Also, as other SoCal drivers may have noticed, this is the time of year when we see a major improvement in fuel mileage, with cooler temps and less AC usage. So I was very happy to pay less and get better fuel economy.
But I did notice a little sluggishness at one point (even with my normal dosage of Primrose), and needed fuel when an Arco station along I-5 was my best choice. And within a few minutes of driving I noticed that the sluggishness was gone. Also, I'm nearing the end of my 2nd tank of Arco, and I can tell that it has not resulted in lower fuel economy. So, I believe right now Arco customers are getting a high cetane fuel, with good BTU content, and at a competitive price.
Maybe Arco fuel was not as good during that earlier period. But there are variations between refineries, and variations between different batches from the same refinery. It's my opinion at this time, based on a lot more experience, that at least in SoCal there is no brand that is always the best or always the worst.
I tried but failed to find the date I started using Primrose. I think it was around March 2004. I've added Primrose to every tank since then except biodiesel.mazot said:Tornado, do you add additives? I think additives may make the mileage/performance difference between ULSD and regular D#2 trivial.
Retarded timing also increases PM (soot) emissions. IOW, more smoke!dieseldorf said:reduced fuel economy
poor performance
rough running
hard starting
etc.
From the Chevron website:eetsoot said:I've read that all Cal diesel is supposed to be low sulpher, less then 50ppm. ECD is less then 15ppm.
Here's some info on ULSD.imsos04 said:Do you think ULSD will cost much more than "regular" diesel?
