Replacing the camshaft
AllenAlic
Portage In
05 Passat TDI Wagon
Ordered a new cam and kit, have a bad lobe on my 05 with 296000 miles. Any tips or tricks out there? Any info or things to watch out for are appreciated.
Windex
Cambridge
05 B5V 01E FRF
Biggest watch-out seems to be the break-in procedure for the new cam. Involves a high-zddp break in oil and some specific instructions. Failure to follow proper break-in has led to a number of reports of premature failure on replancement cams in BHW, BRM, BEW engines.
There is also a special puller to get the cam pulley off the cam - you're going to need to buy or borrow one.
Also good to do the timing belt at the same time, but not absolutely necessary.
AllenAlic
Portage In
05 Passat TDI Wagon
All done, what a difference. One lifter was holed, and one lobe on the cam was flat. Didn’t have to pull the tandem pump, but loosen the 3 bolts that are easiest to get to, that gave enough flex to slide the new cam back in. Can’t believe what a difference this made, like a new car. Half a million miles here we come.
igiveup
Mississauga, Ontario
2005 Passat, 2009 Jetta
I'm also heading down this road. Any opinions on the Aimco camshaft kits on Ebay? Not too crazy about the idea of dropping another $800 on this car.
Mozambiquer
Versailles Missouri
I wouldn't recommend an eBay kit... They won't last long.
