hutchman
- Joined
- Sep 6, 2005
- Location
- Virginia
- TDI
- 2006 Jetta TDI Pkg 1, 5 Spd, Graphite Blue / 2002 Jetta GLS, Black w/tan leather
Getting ready to replace suspension on my 02 Jetta and need the replacement part numbers of all the "use once" TTY bolts and nuts that I'll encounter.
I have been searching the forums but haven't found anything like this.
If anyone sells a kit that would be good to know too.
I'm replacing all the bushings and struts (swaybar, control arm etc.).
Also replacing the clutch so may just go ahead and drop subframe to make that job easier so will need replacement bolts related to that area too. I have the bolt kit for the clutch (flywheel/pp, engine mounts etc.).
Thanks!
Brian
Thanks!
Brian
