Hi Lito,
Here are the wiring diagrams, a little bit on the large size. I'll try to clean them up so they're a little more manageable when I get home tonight. I knew I should've bought the Bentley CD in addition to the hard copy...
Some thoughts on the following:
8. Remove some of the wires from T10 and re-route them to T18c.
On the 2000s there are two wires that belong to the glow plug circuit that I don't think you have here at T10
Agreed. There should be 3 wires from T10e to T18c.
9. Connect appropriate pins on T18c to T5b (cancelling ring)
On my car, this is only 1 wire from T18C to T5b. T5b already had 4 wires: 2-airbag, 2-horn
Same on mine, just 1 new wire needed.
10. Connect appropriate pins on T18c to T10s (Cruise on/off)
Is T10 the black connector in the water-tight box? I'll assume so
T10e is the black connector in the water-tight box. T10s is the connector on the steering column for switch E45 (Cruise on/off). I think T10s/7 goes to T10e/3, T10s/6 goes to T18c/12 and T10s/4 goes to T18c/4.
11. Connect appropriate pins on T18c to T20 (radio)
This should only be one wire(Can-bus). At least on mine it was only one wire
Same here.
12. Connect appropriate pins on T18c to T32a (cluster)
I guess this is your cruise control light?can you please tell me which pins on T18c & T32a these are?
I may not be interpreting the diagram correctly here, but it looks like T18c/1 goes to T32a/9 for B230 Low-Bus, and T18c/3 goes to T32a/8 for B229 High-Bus. I believe the cruise light is activated by can-bus?
13.Connect appropriate pins on T18c to dimmer, horn relayone wire, power, ground...
make sure you choose the correct power wire and not one that is controlled off the light switch, don't ask me how I know this
Kinda hard not to ask with bait like that...
The OEM non MF Setup
Pinout on the MF Control Unit
New wiring
[ February 26, 2003, 16:18: Message edited by: Thom ]
