Replacing rear sway bar
Mbahcall
Home of EAA
2013 Passat Sel
How hard is it to replace and is there any special tools or tips needed. Also what torque specs are used on the various fasteners.
MichaelB
SE Wisconsin
2014 Passat SE DSG
Coffeemade
Hoodbridge, Va
2012 VW Passat TDI SEL Prem
Rear sway bar is totally worth it and if you are already doing front suspension work, then yeah install that while you're at it.
Rear sway bar can be installed on the ground and is really simple.....for the front unless you have a lift, pay for it to be done at a shop.
