timsch
- Joined
- Nov 12, 2009
- Location
- Brookside Village, Texas
- TDI
- 2003 Mk4 Jetta (blue), 2003 Mk4 Jetta (black)
Hello all, I'm in the process of replacing a 10mm IP with an 11mm one. I'm following these instructions and am at the point where I'm to slip the TB off the camshaft and IP sprockets after loosening the tensioner counter-clockwise. Problem is the TB is still mighty tight on these sprockets. I've double & triple checked the tensioner and prodded it with a screwdriver to make sure it's at the loosest setting. I can probably get it off, but it will be a chore.
Looking at the 2nd page for reinstallation, there are instructions to remove the camshaft sprocket to make it easier (or allow) you to reinstall the TB. I don't know if there were reasons not to include the removal of this sprocket for the removal of the TB, but I don't want to proceed without getting advice in case there's something I'm missing.
