McBrew
In hopes to cure the "Quantity Adjuster - Upper Limit Reached" CEL I've been getting from time to time, I've just replaced the fuel temperature sensor. The sensor resides just under the cover of the fuel injection pump. Although one special tool is required, the job is quite simple.
Tools required:
10mm nut driver (or socket) to remove engine cover
3/8" ratchet handle
5" (at least) extension
TX30 socket (male, non security or security)
TX10 socket (male, non security or security)
13mm socket
MetalNerd injection pump tool
1 wire-tie (optional, but recommended)
some rags
Part required:
Fuel Temperature Sensor VW part no. 028 906 040 C
After removing the engine cover, you'll need to remove the injection pump cover. FIRST, place a wad of rags in front of the injection pump to catch the diesel fuel that spills out. These bolts are not very tight... even a 1/4" ratchet will remove them easily. Use a TX30 bit to remove three of the bolts. Use a 13mm socket on the DieselGeek adapter to remove the triangle bolt. Now the top will remove, and some fuel will spill out.
Use a wire-tie to secure the cover and keep it out of the way. I used a clean rag to soak up some of the diesel fuel around the sensor. Note the position of the sensor. It looks like it could be installed upside-down, which may or may not affect it's operation.
Use a TX10 bit to remove the two screws holding the sensor. This could easily be done with a nut driver, as they are not especially tight. Remove the sensor, then follow the instructions in reverse to finish the job. Use a clean rag to wipe off the mating surface between the cover and the body of the injection pump.
After the install, my car started up without a hitch. During the initial test drive, I'd swear my car's performance is up a bit. Probably back up to what it used to be. Maybe the failing temperature sensor was acting exactly opposite of a tuning box or Evry mod.
Sorry, I don't have exact torque specs for the bolts. I put them back on about as tight as they were. They were not very tight at all. Of course, I tightened them in a cross pattern, to help it seat properly and evenly.
I'm sure someone around here has the proper torque specs...
-Jesse
Tools required:
3/8" ratchet handle
13mm socket
some rags
Part required:
-Jesse
