I agree with garciapiano on most everything. The only thing I might change is that I have been less than impressed with the KYB struts than the Bilsteins, but I am not impressed with how long the Bilstein TC's last.
Also, check your springs before taking anything apart to make sure you don't need something you don't yet have. I have seen a number of broken springs over the years that people didn't know were broken. Keep in mind the rear wagon springs are taller than the sedan springs by a little. I ran wagon springs in my sedan to give it a little height.
I also agree with looking at and/or replacing your front control arm mounts at the same time, just be careful unbolting them, so don't just hammer on them with an impact gun as you may snap the internal nuts off resulting in more work. I did not cut the hole here as I use a hole drill, but I did weld the nut back on and then weld a patch over the hole.
The front mounts can be replaced easily if you have a large socket set and some threaded rod. I've done tons of them that way.
For the fronts, I suggest buying the HD strut mount. Normally I will have nothing Meyle on my car but these have held up well, better than the OEM mounts. They can be found a few places and the part number is
357412331AMY. You can see the difference in the picture below, and they don't crush as easily, which results in front end sag. (HD on right)
For the rear axle beam bushings, I used to have to do them once a year due to the car tearing them up. We made a tool that really helps from some 2" pipe end caps but I used to do it with just shims and some threaded rod. It's much easier with a tool. The axle beam doesn't have to be removed from the car so no need to crack into the brake system or remove the struts if you don't want to.
