Stealth TDI
Pre-Forum Veteran Member
Hello,
I like the sound of the Fender Premium Audio system. It's very good for a factory system. However, the subwoofer lacks independent control and it's not *quite* deep enough for me. It's *almost* there, but not quite. Therefore, I decided to move my 10" sub system from my Mk3 to my Mk6. I like to hide things and maintain a stock appearance. So, for now, I'm building a box that'll go into the spare tire well:
This is the first box I've built myself. I've always bought them in years past. I decided to use 3/4" MDF and had Home Depot make the major cuts for me...
I did the rest with a circular saw and a jig saw. Here's the box after I had built it and placed the components for mock-up...
This is after I added bracing, and sanded-down the imperfections, which were many due to my lack of a table saw...
This after I carpeted the box. It was my first time and things did not got well. There's plenty of glue overspray...
I used to GooGone to remove the overspray. It worked great, but I used too much along this seam and ruined the glue's adhesion...
I cleaned that all up with isopropyl alcohol and a heat gun. Then I did some patchwork with my carpeting. I did not want to re-carpet the whole box since the majority of it will be out of sight. This photo shows some patchwork as well as the connections for my amp...
While I worked on all of this, I got a great deal on a new 10" Rockford Fosgate sub. So I will not be re-using my very old DEI sub. Here's the completed box, ready to replace the spare tire...
To be honest, I don't like the idea of being without a spare tire, even though the majority of my travel is within 50 miles of home. I'm already brainstorming an idea which will involve retaining the spare tire and perhaps using a false floor. That'll be a winter/spring project.
Continued in next post...
