Hello.
I started noticing the revs jumping and coming back down quickly when my Golf Sportswagen is in 5th gear at around 2.1K rpm. I guess it is the plate slipping under the force from the turbo that kicks in.
The car has around 80K miles on the clock, Stage 2 Malone tune.
I will be looking for a shop to do the replacement.
So, my questions are as follows:
1. How do I select the kit? By manufacturer and by the torque its capable to handle? My understanding is I can ask the dealer the info on what flywheel my car has and buy the kit from that manufacturer. Does this sound right?
2. Does the shop have to have any additional qualifications specific to MK7 VW? Should my mechanic that did the clutch job on my Miata be able to do the work on the VW?
3. It would be wise to replace the clutch releasing bearing and the rear main seal at the same time. Correct?
I appreciate your help.
