??? Why on Earth would you need 5 acres of solar panels? That would be 20,000kW (~30,000,000kWh/yr) not 10kW (15,000kWh/yr). 10kW can easily cover 100% of the use (car & home) for most people. A thrifty DIY'r can install 10kW of solar for ~$7k. A lifetime supply of energy for $7,000. Over 20 years that's ~300,000kWh. An EV can go ~1M miles on 300,000kWh. You'd need to burn 20,000 gallons of diesel to drive ~1M miles at a cost of $100,000. $100,000 for diesel or $7,000 for solar.
Several questions for you Chris, since I know you're also college educated. Where are your citations for the above information? One thing that was instilled into us practically daily in grad school -
cite your sources. Otherwise, I'm concerned you're just making up these numbers as you go.
My point was that in terms of miles driven you get more miles from 1kW ~3 solar panels (~1,500kWh/yr, ~4,000 miles) of solar as you would from an acre of soybeans (~70 gallons, ~3,500 miles). Which.... which is kinda crazy. So
@pkhoury 3 300w solar panels will yield more miles per year in an EV than an entire acre of soybeans would in a TDI.
My main concern, which I bring up over and over, is that I can't seem to find an EV that gets comparable range, towing of at least 3000 pounds, and will cost me under $10K. I'm done having car payments, and I know a lot of others who have the same sentiment.
Paying ~$0.10/mile for diesel instead of ~$0.02/mile for electric or < $0.01/mile from solar is 'thousands of times' cheaper? Do you drive less than a mile a week? If that's true I agree that an EV makes little sense for you.
Depends - some days, I might drive 3 miles to go to the post office and back. Other days, like yesterday, I might put in 232 miles. I don't know how many miles I've already driven this year, but I think I'm in the 15-20K mile range, of which at least a third of that is towing long distances.
I just did a quick google search -
this site claims 2000 miles for the Tesla Model 3, but of course, no towing capacity in the US.
Tesla
here says 3500 pounds for the model Y, but it's a staggering $1300 for that option. I just installed a replacement Bosal hitch last night. Took about two hours of my time on wet ground/mud to swap hitches, and mine cost around $350, when idparts used to sell them. Buy from pfjones, and I'm looking at around $450 after shipping. That's still a far cry from $1300.
Then the cost of the car.
Of course, this is assuming someone gets 3.24%, depending on their credit worthiness. Except for the t-reg/Audi owners, I don't think any of us paid more than $30K-ish for their TDI (not sure what Passats were when new).
Lastly - I have yet to see Tesla offer estimated ranges with towing. I know with both my common rail and my ALH, I'm looking at 21-31mpg while towing, depending on what I'm towing. If it's a parachute, like my livestock trailer, definitely 21-23mpg. My 4x6 home built trailer? 30-33mpg when loaded with about 1500 pounds of feed.
I just checked
this map to see where Tesla Supercharging stations are on I-10, and they're a little over 100 miles apart. I guess it's right to assume I should be able to get at least 150-200 miles per charge on a Model Y, towing about 2000-3000 at 75-80mph with the AC going full blast?
