RV8 Mike said:
OK, so maybe I'm asking the obvious, but how do you remove the grill?
Easy. Open hood. Two torx screws toward the sides of the grill in front of the radiator, unscrew from the top. Two more torx screws under the front bumper, below and to either of where the front license plate is (or would go, if you don't have one); unscrew from the front. Then you basically just pull it off from the top, tip it forward and pull it up and out from under the bumper cover. I think that there are also 2 little plastic clips on the top, close to the center, it's easy to see how they release. With a torx screwdriver, it ought to take you about 5 minutes or less, and much less after you've done it once.
Sorry I don't have a convenient picture.
Have Fun!
Don
