Relay removal
Sam Hamburger
Florida
2013 Passat SE TDI
Hello fellas, I am trying to pull the relays that are located under the steering column. I have removed the door and purchased relay pliers.
The big problem seems to be nylon fence that is holding the relays in position. Is there a proper way to remove the fence? Thanks!
Sam Hamburger
Florida
2013 Passat SE TDI
Thanks again. If you remove the door above your left knee you will see more relays. They are not easy to access.
