Turbo Steve
- Joined
- Jan 11, 2000
- Location
Since Prevention is much better than Redemption, it makes sense to replace the Relay 109 Circuit Fuse before it gets too hot and leaves you stranded.
Here's what to do:
Contact VW Parts.com (AKA Impex World Distributors) at http://www.vwparts.com / (800) 736-3550 and order VW Part #1J0906381A for $17.65 plus $4.42 shipping. (This part fits most late-model VW TDI's.)
I also recommend ordering two of these critical parts in order to keep a second newly-designed circuit as a spare.
Installation is literally a snap. After removing the driver's side under-dash panel (two T-15 Torx screws), simply use a flashlight to look-up where the fuses are and remove the largest fuse - Relay 377 - and carefully set it aside.
Directly above the empty slot (where Relay 377 used to be) is Relay 109, which can now easily be removed and replaced. Everything can now be put back together in reverse order.
Note - The newly-designed Relay 109 is gray in color and slightly smaller than the older black model, which tends to fail under hot temperatures.
Here's what to do:
