Regen issue?
relumalutan
Michigan
2011 Audi A3 TDI, 2006 VW Jetta (Sold)
I'm new to the CBEA platform, coming from a 2006 MK5 Jetta TDI.
Bought a 2011 A3 with 129k miles 6 days ago. I scanned it with VCDS, no errors. Everything was fine for the first 2 days, on the third evening after a 20 minutes 15 miles uneventful drive from work in 70 degrees weather with no AC on I noticed the fans kept running after I turned the engine off. It appeared the exhaust was hot, so I thought to myself: this must be the mythical DPF regen. that I heard of. So I turned the engine back on and let it idle for a while. This time the fans turned off when I turned off the engine after 5 minutes.
Same thing happened again the following two evenings. It does not happen during the day, no matter how long I drive the car. It always happens at night after my 20 minutes drive from work. Did some research, came around this posting: https://www.audiworld.com/forums/a6-c7-platform-discussion-194/cooling-fan-staying-2860392/
It appears there are two opinions:
1. The fans running to cool of the turbo. It does not make much sense to me, why the fans don't run during the day after driving a long distance?
2. The thermostat being bad, and not being able to maintain a high enough engine temperature for the regen. to successfully complete. The thermostat needle on the gauge usually sits slightly below the center.
What you guys think might be the issue? I thought the regen should occur on average once a month or 700 miles.
TurboABA
Kitchener, ON
The issue is you don't know how to use VCDS.
Post full scan, then post your DPF stats and regens stats.
pedroYUL
MI, USA
2015 Passat CVCA; 2015 GSW CRUA; 2012 wagon CJAA; 2004 wagon BEW(brother)
To me, it sounds like you interrupted a regen, then the car tries again to complete it, and maybe you interrupted it again?
