tyler_01_TDi
I recently purchased a set of BBS RX II wheels that need refinishing. I have read a bit of info online about the process and was hoping to get some advice from someone who has refinished these before.
First, getting the triple square bolts out. I have read that sometimes these can be a real bear. Is there a sure fire way of removing these bolts without damaging them? I saw a picture of an entire wheel in a kitchen oven. My neighbor happens to be remodeling their kitchen – I could probably get their old oven to evenly heat the wheels if this will help. Any suggestions would be appreciated.
Once the wheels are apart I was thinking of just having the centers blasted and powder coated. I'd like to restore the brushed finish on the barrels so, to remove whats left of the original finish from them without being too aggressive, I was thinking of using a chemical stripper. Once the brushed finish is restored I was thinking of having them powder coated as well (If there is such a thing as clear powder coat). Questions: will chemical stripper remove the old finish? Will the tolerances of the wheels allow for the thickness of powder coating (Aka - will I be able to get the center back into the barrel after powder coating)?
