Recall emission mod performed at 68,873 miles in April 2018. With less than 100,000, still have 6 months remaining on the modification warranty.
catfish_hunter
ohio
2011 TDI Golf MT
Have had several warranty covered repairs in the past few years:
- 2013 Received a "control unit flap" (036128063T)
- 2018 Received an oxygen sensor kit
- 2019 Received an intake manifold
- 2021 Dealer scan found P0638, possible faulty throttle body (J338). Dealer performed throttle body adaption to ECU. Dealer stated that if fault returns, they will replace the throttle body assembly.
- 2021 Dealer determined that there was a faulty actuator in the throttle valve housing. Dealer installed a second ((036128063T) control unit. Then dealer noted a "long crank time" and scanned a P0638 fault code, so finally replaced the throttle valve housing (J338).
During the past winter I had two occasions when the engine would not turn over (Ohio winter). First event was around Christmas; I boosted the battery and finally got the engine to turn over and got it started. Then in early-March, the engine would not turn over again (battery tested fine). Thanks to this forum I realized that this was an intercooler / piston cylinder hydro-lock event. Pulled the glow plugs and purged water from the cylinders by cranking the engine, then successfully started the engine.
During the recent week, the engine has been stammering more than usual. The yellow engine light finally came on a couple of days ago.
I have 6 months remaining in my 4 year +6 month warranty, so it's going back to the dealer next week.
I bought a VCDS a couple of months ago, but I have not learned to do much with it yet. I auto-scanned it in February and things seemed to be in order. I performed the auto-scan again today, and several "malfunctions" were listed.
I thought I would share the auto-scan info to see if anyone can offer some feedback about anything before I take the car to the dealer.
Auto-scan 4-17-2022, 2011 VW Golf TDI:
01-Engine -- Status: Malfunction 0010\par
03-ABS Brakes -- Status: OK 0000\par
04-Steering Angle -- Status: OK 0000\par
08-Auto HVAC -- Status: Malfunction 0010\par
09-Cent. Elect. -- Status: Malfunction 0010\par
15-Airbags -- Status: OK 0000\par
16-Steering wheel -- Status: OK 0000\par
17-Instruments -- Status: OK 0000\par
19-CAN Gateway -- Status: OK 0000\par
1C-Position Sensing -- Status: OK 0000\par
25-Immobilizer -- Status: OK 0000\par
2E-Media Player 3 -- Status: OK 0000\par
42-Door Elect, Driver -- Status: OK 0000\par
44-Steering Assist -- Status: OK 0000\par
46-Central Conv. -- Status: OK 0000\par
52-Door Elect, Pass. -- Status: OK 0000\par
56-Radio -- Status: Malfunction 0010\par
62-Door, Rear Left -- Status: OK 0000\par
72-Door, Rear Right -- Status: OK 0000\par
77-Telephone -- Status: OK 0000\par
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb\par
Part No SW: 03L 997 030 C HW: 03L 906 019 DA\par
Component: R4 2.0l TDI G000SG 9983 \par
Revision: 12H14--- Serial number: \par
Coding: 0050072\par
Shop #: WSC 15680 002 1048576\par
VCID: 2E0501028C1C315B05D-807A\par
VINID: 9E69DE74745A1129C22071011C7B374E87\par
\par
6 Faults Found:\par
001649 - Cylinder 1 Glow Plug Circuit (Q10) \par
P0671 - 000 - Electrical Fault - Intermittent\par
Freeze Frame:\par
Fault Status: 00100000\par
Fault Priority: 2\par
Fault Frequency: 1\par
Reset counter: 255\par
Mileage: 154324 km\par
Time Indication: 0\par
Date: 2016.08.04\par
Time: 17:52:02\par
\par
Freeze Frame:\par
RPM: 0 /min\par
Speed: 0.0 km/h\par
Voltage: 12.01 V\par
Temperature: 15.3\'b0C\par
Bin. Bits: 00110000\par
Time: 2.52 s\par
\par
001650 - Cylinder 2 Glow Plug Circuit (Q11) \par
P0672 - 000 - Electrical Fault - Intermittent\par
Freeze Frame:\par
Time: 17:52:02\par
\par
Freeze Frame:\par
RPM: 0 /min\par
Speed: 0.0 km/h\par
Time: 2.52 s\par
\par
001651 - Cylinder 3 Glow Plug Circuit (Q12) \par
P0673 - 000 - Electrical Fault - Intermittent\par
Freeze Frame:\par
Time: 17:52:02\par
\par
Freeze Frame:\par
RPM: 0 /min\par
Speed: 0.0 km/h\par
Time: 2.52 s\par
\par
001652 - Cylinder 4 Glow Plug Circuit (Q13) \par
P0674 - 000 - Electrical Fault - Intermittent\par
Freeze Frame:\par
Time: 17:52:02\par
\par
Freeze Frame:\par
RPM: 0 /min\par
Speed: 0.0 km/h\par
Time: 2.52 s\par
\par
000524 - Cylinder 3 Injection Timing \par
P020C - 000 - - Intermittent - MIL ON\par
Freeze Frame:\par
Fault Status: 10100000\par
Fault Frequency: 8\par
Mileage: 156177 km\par
Date: 2016.09.02\par
Time: 15:44:10\par
\par
Freeze Frame:\par
RPM: 1932 /min\par
Speed: 52.0 km/h\par
Load: 22.0 %\par
Bin. Bits: 00100010\par
Torque: 36.0 Nm\par
Ign. Timing: 22.1 \'b0ATDC\par
\par
004102 - Torque Difference Cylinder 3 \par
P1006 - 000 - Limit Value Exceeded - Intermittent\par
Freeze Frame:\par
Mileage: 156264 km\par
Date: 2016.09.05\par
Time: 16:02:14\par
\par
Freeze Frame:\par
RPM: 1955 /min\par
Speed: 34.0 km/h\par
Load: 20.0 %\par
Torque: 0.0 Nm\par
Bin. Bits: 00000010\par
Ign. Timing: 18.4 \'b0ATDC\par
\par
Readiness: 1 1 0 0 0 \par
\par
-------------------------------------------------------------------------------\par
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb\par
Part No SW: 1K0 907 379 BG HW: 1K0 907 379 BG\par
Component: ESP MK60EC1 H31 0106 \par
Revision: 00H31001 \par
Coding: 114B400C492A0001880F02E592200042B70000\par
Shop #: WSC 01357 011 00200\par
VCID: 78A9E75A32D83FEB9F1-802C\par
\par
No fault code found.\par
\par
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb\par
Part No SW: 7N0 907 426 AC HW: 7N0 907 426 AC\par
Component: AC Manuell H18 0303 \par
Revision: 00013001 \par
Coding: 0000001002\par
ASAM Dataset: EV_ACManueBHBVW36X A01010\par
ROD: EV_ACManueBHBVW36X_VW36.rod\par
VCID: 75B7EE6E254A4283847-8020\par
\par
2 Faults Found:\par
9474577 - Motor for Recirculation Flap \par
B1092 11 [009] - Short to Ground\par
Confirmed - Tested Since Memory Clear\par
Freeze Frame:\par
Fault Status: 00000001\par
Reset counter: 39\par
Mileage: 149548 km\par
Date: 2021.08.15\par
Time: 20:31:37\par
\par
9481200 - Refrigerant Pressure \par
B10AB F0 [009] - Too Low\par
Freeze Frame:\par
Fault Frequency: 5\par
Reset counter: 12\par
Mileage: 150536 km\par
Date: 2021.10.04\par
Time: 06:24:29\par
\par
\par
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb\par
Part No SW: 1K0 937 086 L HW: 1K0 937 086 L\par
Component: BCM PQ35 M 104 0623 \par
Revision: 00104 AF \par
Coding: 6D180A1A90272AC4008800817000854440010086534D8560648020200040\par
VCID: 392F225E4952E6E3A0F-806C\par
\par
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB\par
Component: Wischer 17031 26 0512 \par
Coding: 009795\par
\par
1 Fault Found:\par
00332 - Control Circuit for Tank Flap \par
007 - Short to Ground\par
Freeze Frame:\par
Fault Status: 01100111\par
Fault Priority: 4\par
Reset counter: 70\par
Mileage: 138827 km\par
Date: 2014.07.05\par
Time: 10:15:27\par
\par
Freeze Frame:\par
Term 15 Off\par
Voltage: 13.20 V\par
OFF\par
ON\par
Term 50 Off\par
OFF\par
OFF\par
\par
\par
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb\par
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B\par
Component: AirbagVW10G 021 0706 \par
Serial number: 003C4R0223MW \par
Coding: 00003031\par
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012\par
ROD: EV_AirbaVW10SMEVW360.rod\par
VCID: 392F225E49D2E6E3A0F-806C\par
\par
Seat occupied recognition: \par
Subsystem 1 - Part No SW: 5K0 959 339 HW: 5K0 959 339 \par
Component: BF-Gewichtss. 007 0002 \par
Serial number: ---0000R--0005C0X500\par
\par
Crash sensor for side airbag: driver side: \par
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354 \par
Component: S.Sens.Fahr.V H01 ---- \par
Serial number: 3572MSME5D71245DZZZ0\par
\par
Front Passenger's Side Airbag Crash Sensor: \par
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354 \par
Component: S.Sens.Beif.V H01 ---- \par
Serial number: 3582MSME4555245DZZZ.\par
\par
Rear Side Airbag Crash Sensor (on driver's side): \par
Component: S.Sens.Fahr.H --- ---- \par
Serial number: 3512QSME6E271D7EZZZC\par
\par
Passenger side rear thorax airbag crash sensor: \par
Component: S.Sens.Beif.H --- ---- \par
Serial number: 3522QSME74210001ZZZ7\par
\par
Crash sensor for front airbag: driver side: \par
Component: F.Sens.Fahr --- ---- \par
Serial number: 35527SME6A0F7526ZZZR\par
\par
Crash sensor for front airbag: front passenger side: \par
Component: F.Sens.Beif --- ---- \par
Serial number: 35627SME2B277526ZZZJ\par
\par
\par
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb\par
Part No SW: 5K0 953 507 BC HW: 5K0 953 549 E\par
Component: Lenks.Modul 008 0080 \par
Revision: -------- Serial number: 90440KCO000TA\par
Coding: 108A140000\par
ASAM Dataset: EV_SMLSNGKUDS A05001\par
ROD: EV_SMLSNGKUDS_A05.rod\par
VCID: 72BDD572542455BBA15-8026\par
\par
Multifunction steering wheel control module: \par
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB\par
Component: E221__MFL-TK6 H06 0022 \par
Serial number: 40000000000000297095\par
Coding: E20000\par
\par
\par
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1\par
Part No SW: 5K0 920 971 C HW: 5K0 920 971 C\par
Component: KOMBI H20 0420 \par
Serial number: 00000000000000\par
Coding: 270F01\par
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089\par
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod\par
VCID: 2F3B1C06879638530EB-807A\par
\par
\par
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb\par
Part No SW: 7N0 907 530 C HW: 1K0 907 951 \par
Component: J533 Gateway H37 0614 \par
Revision: H37 Serial number: 300311F1002972\par
Coding: 350002\par
VCID: 30391F7A9A2827AB171-8064\par
\par
\par
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl\par
Part No SW: 5N0 919 879 HW: 5N0 919 879 \par
Component: Kompass 001 0001 \par
Revision: 00001000 Serial number: 1225223RCPNE06\par
Coding: 0000002\par
VCID: 7EA5F1421CFC01DBD5D-802A\par
\par
\par
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb\par
Part No SW: 5K0 953 234 HW: 5K0 953 234 \par
Component: IMMO H20 0420 \par
Coding: 000000\par
Shop #: WSC 00000 000 00000\par
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008\par
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod\par
VCID: 6A8DCD127CF49D7B195-803E\par
\par
\par
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl\par
Part No SW: 5N0 035 342 D HW: 5N0 035 342 D\par
Component: SG EXT.PLAYER H13 0150 \par
Revision: A1001003 Serial number: 7669312555 \par
Coding: 010000\par
VCID: 2809F71AA2F86F6BCF1-807C\par
\par
\par
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb\par
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B\par
Component: Tuer-SG 009 2119 \par
Coding: 0001204\par
VCID: 313F1A7E9D222EA318F-8064\par
\par
\par
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb\par
Part No: 1K0 909 144 M\par
Component: EPS_ZFLS Kl. 70 3201 \par
Revision: 00H20000 \par
VCID: 3431136A62301B8B739-8060\par
\par
\par
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb\par
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B\par
Coding: 0001204\par
VCID: 323D1572982415BB615-8066\par
\par
\par
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb\par
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC\par
Component: Radio Prem-8 H16 0044 \par
Revision: -----28S Serial number: VWZ4Z7L1110432\par
Coding: 0100040004\par
VCID: 619FAA3E8142DE23C8F-8034\par
\par
1 Fault Found:\par
02635 - Tuner Not Enabled/Activated \par
000 - -\par
Freeze Frame:\par
Fault Status: 01100000\par
Fault Priority: 7\par
Fault Frequency: 2\par
Reset counter: 228\par
Mileage: 145912 km\par
Date: 2015.08.14\par
Time: 13:04:34\par
\par
\par
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb\par
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D\par
Component: Tuer-SG 007 2101 \par
Coding: 0001168\par
Shop #: WSC 01357 011 1012552\par
VCID: 35372E6E694A0283447-8060\par
\par
\par
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb\par
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D\par
Coding: 0001168\par
VCID: 36352962744C099B4DD-8062\par
\par
\par
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb\par
Part No SW: 5K0 035 730 HW: 5K0 035 730 \par
Component: TELEFON H09 1020 \par
Revision: 1B001001 Serial number: 00007669639254\par
Coding: 0A00000000010100\par
ASAM Dataset: UHVNA A01009\par
ROD: UHVNA.rod\par
VCID: 629DA53284C4C53BD15-8036\par
\par
\par
End----------(Elapsed Time: 01:10, VBatt start/end: 12.0V/12.0V)-----------\par
Zawurah
The Morning Star
Dieselgate has little to do with requests to diagnose your car.
What model year is your car? The 4 year 'since emission repair' warranty expires this month. The only warranty coverage you might still have, is the 'since vehicle first in service' 10 year 120k warranty.
If you have a warranty, then let the dealer fix it.
If you want to fix it yourself and want help, then post in a different subforum.
catfish_hunter
ohio
2011 TDI Golf MT
Volkswagen Emissions Modification Programs
Vehicle (VIN) Included in Settlement:YES
Modification Approved by EPA and CARB:YES
Modification Completed for this Vehicle (VIN):YES
Vehicle has Extended Emissions Warranty:YES
Vehicle Eligibility and Emissions Modification Status:
An emissions modification has been approved for this vehicle by EPA and CARB. Please see below for additional information regarding the emissions modification.
Emissions Modification Disclosure:
Please find details on the modification for the vehicle in the Emissions Modification Disclosure.
Extended Emissions Warranty Information*:
The vehicle has an Extended Emissions Warranty that runs for 10 years 6 months or 126,000 miles from the original in-service date. Please see your VW dealership for additional information including the vehicle's in-service date.
In addition, and concurrently, the Extended Emissions Warranty runs for 4 years 6 months or 54,000 miles (whichever occurs first) from the date of modification or first dealer resale post-modification. Your vehicle was modified on Apr 26, 2018 and 68,873 miles. Please see your VW dealership for additional information on the vehicle's post-modification dealer re-sale date.
catfish_hunter
ohio
2011 TDI Golf MT
Zawurah
The Morning Star
I'm not sure how you got an extra half year of coverage on top of the usual 10 year and 4 year settlement terms, but good for you.
Edit: I found that vehicles with a manual transmission get the extra half year of coverage.
hertdi
Puget Sound
14 JSW
Ugh, that extra half year would have been great. My dieselgate warranty expired about 3 weeks ago and I JUST got my first emissions code (p0638). Sigh...
