Mozambiquer
- Joined
- Mar 21, 2015
- Location
- Versailles Missouri
- TDI
- 2004 VW Touareg V10 TDI, 2012 Audi Q7 V6 TDI, 1998 VW Jetta TDI. 1982 VW Rabbit pickup, 2001 VW Jetta TDI, 2005 VW Passat wagon TDI X3, 2001 VW golf TDI, 1980 VW rabbit pickup,
Starters and alternators are things that baffle many mechanics, let alone the guy who just wants to drive his car and change his oil... I'm a starter and alternator rebuilder, and want to show that it's not some voodoo magic that only special guys can do. Anybody with a few tools and the correct parts can rebuild their own starter.
This starter is a Bosch starter from a mk4 jetta tdi. Other Bosch ones are similar. Vw also used Valeo, and some mitsubishi units.
Some of the principles apply, but they won't be the same.
Before.
First step is to remove the two screws in the middle of the back housing.
Then Remove the cap and the "c" clip around the armature shaft
Remove the two 7mm head through-bolts then Remove the back cap.
You are now looking at the back of the armature and the brush holder.
Remove the 13mm head nut from the solenoid, then work the brush holder out
Next step is to pull the field and frame assembly off along with the armature.
You are now looking at the planetary gear assembly. The cover for it may have come off with the field and frame assembly, if so, just pop it out of there. As a note, be careful not to set the fields over metal shavings... If you get shavings in there, it can be a big pain to get them back out and off of the magnets.
Next, flip it over and use a t25 bit to remove the three solenoid mounting screws.
Remove the solenoid and then Remove the planetary gears. I replaced the drive, which is a HUGE pain. The drive is normally good still on these starters. You can tell though by turning the drive by hand while holding the planetary gears still. It should go smoothly one direction, and then not turn the other direction. If it doesn't, it should be replaced. Needless to say, I did replace the drive on this one, and during the struggle, I didn't take photos. I'll have to do another one and take photos of it.
There are all the parts for the starter spread out on the table.
Now, time for cleaning and painting if desired. I have access to an aqueous parts cleaner which does an awesome job, but a can with mineral spirits and a paint brush could work too.
Here's the parts I replaced. The drive, brush holder and solenoid. I used Brazilian made parts, which seem to be pretty good, but not quite as expensive as Bosch.
Reassemble in reverse order and then you have a like new starter!
Before.
