Rebuild will not start HELP!
jokila
Houston, Texas
2003 Jetta GLS, Manual
Not wanting to hijack this thread , but as a colollary query , how does one reset the IQ?? I have a good running 2003 tdi with stage 1 Malone with the IQ at 2.2.... some light smoke which I could do without. Fuel consumption is 45-48 mpg, which I cant complain about but this is Canadian gallons which of course are 25% bigger than US gallons so the reported 50 mpg from US users gets my attention. I believe something in the range 3.5 -5.0 might be worth trying
Use VCDS. Look up Hammer Mod procedure. If you cannot adjust the IQ enough through VCDS you can loosen the IP top cover screws slightly and adjust manually.
sisyphus
Appleton, Maine
99.5, '01 A4 Jetta sedans, 5 sp box, Hamman mod, Joey mod, Bilsteins, 2.00" lift
The head gasket thickness is based on piston protrusion into the head. Too thick would have an effect on cold starts IIRC but I think it would at least start.
jeepinblackdog
Kenosha WI
2003 jetta ALH 2013 Passat
timing was off, by 2 teeth on the flywheel. retimed it and it started up after about 10 rev. But it starts up rough and smoke a lot a startup. Smell like its over fueling. I have my IQ set at 4.8. Should I go higher?
Vince Waldon
Edmonton AB Canada
Was the camshaft sprocket loose and able to turn freely as you tensioned the timing belt with all the alignment jigs in place?
sisyphus
Appleton, Maine
The IQ setting is mg/stroke. So if you crank it up you're going richer. I seem to recall a thread about a slow-down shudder fix that was about changing the IQ. I did it to my cars and it worked but from what I remember, if you're changing it the ECU will compensate to allow the right amount of air. All you need to do is change one thing. So if you add fuel, it will request more air.
If you're running stock nozzles set it at 3, no lower.
jokila
Houston, Texas
You have it wrong on the IQ setting.
from myturbodiesel.com:
"Rules for adjusting IQ and the QA's reactionThe normal range for IQ value on a stock, unmodified car is 3-5 mg/str at idle and 36-38 at full throttle. Too low and the car is overfueling, too high and the car is underfueling.
If you want less fuel you want a higher IQ value, lower software adaptation number, QA moves left towards fuel filter (passenger side for left hand drive cars).
If you want more fuel you want a lower IQ value, higher software adaptation number, QA moves right towards battery (driver's side for left hand drive cars)."
jeepinblackdog
Kenosha WI
Thats what i thought , I have it set to 5.5 (was at 4.8) and it doesnt smoke as much at startup and seems to run better with more power.
Franko6
Sw Missouri
Jetta, 99, Silver`
As for IP (injection Pump) timing and IQ (Injection Quantity), the right number for timing the IP should be right at 50, but we don't make any qualms about setting it at 65 for a brand new belt. In a few thousand miles, it will stretch the belt and go back to 50, so, we set it once and call it good. Advanced timing starts the engine easier.
As for IQ, it really is as individual as the injectors. Age, miles, 'alternative fuel' type, and any mods will change the IQ setting. Years ago, we developed a formula which works very well for setting IQ.
You will need a VCDS and basic tools like the torx that loosens the two top covers on the Injection Pump (IP) so you can move the setting of the Injection Quantity (IQ).
For those who do not have the security bolt tool, we have devised a tool that is `1) inexpensive and 2) easy to make. Find a 1/4" drive 7mm 6-point socket. You will need a die grinder, air supply and a small carbide grinder (or a buddy who has them). We use a 'Christmas Tree" carbide. You can get a great set of 6 carbide cutters from Grizzly Tools Catalog sales. Make the 6 point socket into a triangle tool by grinding out the 7mm socket until you have a 'triangle' tool. Keep fitting against the Security screw until it fits tight. We generally use a hand impact hammer to loosen the security bolt, as it has a tendency to be very tight and strip. It can be replaced with a torx screw. We stock the screw if you want one.
Plug in the VCDS and start the program. Make sure all fans/ AC, headlights etc are turned off. Go to Engine Module/ Adaptations/ Log in12233 and then go to #4 adapation. Block 2. ( I have to check myself on this. Not sure I have the number right) Read IQ number. Move the number to a lower number to make it smoke. If it can't smoke, it can't run. Loosen all the torx screws on the IP to the point you can move the two IP covers by striking the cover with a plastic mallet; not so loose it leaks fuel. Driving the lids towards the driver side makes the IQ number lower and that means more fuel. Raise the IQ (toward the passenger direction) to reduce smoke. Road test...
Find a flat, quiet road that you can drive 45mph without getting introduced to the local police force...
Drive the vehicle to 35mph in third gear. Go to WOT (wide open throttle). At 40 mph, count 3 seconds on stop watch and check mph. On average, it should be 52-54 mph. Raise IQ by either hammer mod or adjusting from engine adaptation section in VCDS to a higher IQ number. Road test. When you lose MPH, lower the IQ number until performance is recovered.
That is the way we optimize fuel economy for the AHU and ALH engines.
After years of doing 'our thing', we have found there is no 'one number' that is right, as there are too many variables.
jokila
Houston, Texas
Yeah. The way he describes it is flawed. It's the ratio of fuel to air that is affected by the IQ adjustment. He says, "The results appear to show that Lowering IQ with adaptation will cause the engine computer to request - and get less air."
It's not the lowering of air by the computer (how would it do that with the ALH?), it's the delivery of more fuel which is in effect being rich.
sisyphus
Appleton, Maine
Aaaauuugh. This hurts my head anymore. Thanks for clearing that up!
jokila
Houston, Texas
That's a great explanation of really making an optimum IQ. Sometimes it seems random how much you can set it to without seeing a noticeable effect. Your method makes it specific.
turbovan+tdi
Abbotsford, BC.
2003 TDI 2.0L ALH, auto, silver wagon, lowered, Colt stage 2 cam, ported head,205 injectors, 1756 turbo, Malone 2.0, 3" exhaust, 18" BBS RC GLI rims. 2004 blue GSW TDI, 5 speed, lowered, GLI BBS wheels painted black, Malone stage 2, Aerotur
Great writeup Frank.
PO, rings take along time to properly seat on a diesel, so recheck compression after 10-20,000 miles. Also, excessive cranking can glaze new cylinders.
jeepinblackdog
Kenosha WI
That is GREAT info I will try that and see what I get. I have already done Hammer mod and can go as high as 7 IQ but never heard of a way to optimally set it. Thanks
hughesjasonk
New York
2002 Jetta MK4;
What speed would you suggest for an auto?
Sent from my SCH-I545 using Tapatalk
jeepinblackdog
Kenosha WI
So did the 3rd gear thing and speed (63mph after 3 seconds) and power kept getting better to 7.0 QI and ran out of adjustment. Will need to Hammer mod it to get more. Is it uncommon to need to go that high or is it due to the 1019 injector tips?
[486]
MN
02 golf ALH
Hopefully you didnt hit valves to pistons with that incorrect cam to crank timing......
Mine was 11 starter ring gear teeth retarded and I drove it 10-15 miles like that. Had to torch the intake manifold to get it started.
turbovan+tdi
Abbotsford, BC.
