gdunn
- Joined
- May 12, 2003
- Location
- Hillsdale, Ontario
- TDI
- Golf, 2k, Green, Auto: Jetta 2003, Black, Manual
I'm sad to say I let my rear wiper blade go WAY too long before replacing it and I've now got some body work to do.
I hadn't noticed, but the tip of the blade was hitting the center portion of the frame of the window and has now removed the paint for about a 1 inch stretch. There are signs of rust starting already.
It looks like, with a properly maintained blade, the arm is lifted far enough off the window to stop this from happening.
I think I'll replace mine with a blade that is 1 inch shorter than what's on it now (it's currently the original blade that came with the car).
From what I've heard of the 10-year rust warranty, it only applies to rust holes coming from 'behind' the metal (so it doesn't cover stone chips and the like from surface damage) (can anyone comment on this?). This is definitely surface damage so presumably won't be covered, although it looks to me like a very obvious design problem. Shortening the blade wouldn't reduce the area cleaned by much, but would certainly ensure this never happens.
I thought others might want to know about this potential problem...
