4x4toy
Looking for a part number for the washer on rear bearings. Time to do bearings again!! Want to put new ones in this time. Had some wear last time.
Thanks.
Thanks.
What is "bearing lock fluid"; never heard of it??I had the problem with the inner bearing spinning on the stub axle, causing the bearing to wear. I replaced the stub axle, but the bearing still spun on it, so I ended up using bearing lock fluid on it. That solved it, no more worn bearings.
