Karan_Takhar
Hello all,
I have a 2013 TDI Passat. The rear left turn signal is malfunctioning. After going over a speed bump, it stopped working and the flasher blinked rapidly, prompting a bulb change message. I replaced the bulb twice, but it kept failing. I tested the light assembly with the rear right side light, and it didn't work either. It could be a faulty harness or flasher. Has anyone encountered this issue and found a solution? Other turn signals work fine, except the left rear.
Thanks!
Thanks!
