d24tdi
Sometime in the last month, with no direct cause that I am aware of, the passenger side rear door of my 2004 B5.5 sedan became impossible to open. The exterior and interior handles both just stroke freely and obviously are not moving anything in the latch mechanism. The lock knob still moves up and down but has no effect on anything.
This is a new problem for me, except for two other factors:
1) This car's rear doors have been oddly intermittent in their response to the interior door release levers for the last year or so. Sometimes passengers in the rear could get out no problem but other times they had to be let out by someone opening the door from the outside, almost as if the child lock was engaged. Never could identify any pattern to this. This issue still affects the driver's side rear door when trying to open it from the inside: sometimes it works, most of the time it doesn't. The handle moves and you can feel it moving the latch mechanism (including unlocking the door if it's locked) but most of the time it doesn't release the latch. It always opens fine from the outside, for now.
2) My 2005 Jetta wagon also has a rear door that is inoperable (driver's side on that car). I am assuming whatever issue is affecting the Passat is also affecting the Jetta and the path to repair will probably be the same too so this question is really about both cars.
I imagine it is probably not a coincidence that rear doors are affected in all these cases. I am guessing there is something that failed with the child interlock inside the latch but who knows.
Anyone dealt with this before? Solutions/tricks?
Am I going to have any options for getting the doors open without destroying something? Probably either an interior door panel or the latch? I can dismantle the door hinges and disconnect door harness at the B pillar but that won't do anything for the latch end of it.
