Texas_sky
Was trying to change out a rear driver side door lock actuator 3B4839015AP on 06 jetta today. I put everything back and secured the cable and before I could get the door skin on I shut the door (after I installed the two 6mm screws on door jam) and it won't open up from the inside or outside. The lever that the outer door cable attaches to is stuck and won't move. I supposed I should have tested the part before I installed it. Any ideas what I can do to open up the door, do the mechanisms and latches have to be adjusted to a certain position before putting everything back together? Car still driveable just no left rear door skin or functioning door.
