Rear camber adjustment
Yai
Greater Toronto Area
2012 Golf TDI, 2014 Touareg- R Line
Hi,
Need a bit of help as been searching around, and not sure and figure I'd ask. I see GSW and GTIs have the eccentric washer/bolt that can adjust camber. I didn't find the same parts for the reg golf TDI, so I'm assuming camber can't be adjusted without some adjustable camber arms? The camber arms look the same, could I simply just use the same eccentric bolt & washer from the GSW/GTI?
I will need to adjust the camber to avoid rubbing in the rear, as my new wheels will poke out a bit.
Thanks,
Ron
