moreforyou
- Joined
- Jul 28, 2003
i've read a post with someone with the same problem, but the solution wasn't clear. i'd like to do anything to avoid going to the dealer, as it's something i really cannot afford.
so basically, the problem is: when i start up the car, the brakes feel rather spongy. as i drive along the brake pedal gets stiffer and stiffer to the point where if i barely press it, it's like slamming on the brakes. if i stop the car and press hard on the pedal, i can bleed the extra pressure off and keep driving. i have to do this every 5 minutes or so, or the brakes will totally lock up.
the first time this happened, i didn't really know what was going on, so i had to basically floor it to keep the car moving. when i stopped the rear brakes were very hot and stunk horribly.
if anyone can shine some light on this problem it would be MUCH appreciated. thank you.
