EMS
- Joined
- May 20, 2000
- Location
- Ottawa, ON, Canada
Hi All...
I'm currently in the process of replacing my rear swing-axle (i.e., trailing arm) bushings on my 2000 Golf TDI. I've got about 160k (100,000Miles). When we removed the axle from the car, the passenger side bushing had disintegrated to a point where the bolt mounting sleeve was separated from the outer bushing by hand and on the drivers' side, the whole bushing assembly had walked out of the axle by about 1/8" or more.
I'm just wondering if anybody else has had to replace these bushings? Personally, I think they've been bad since new, since there was always a squeak from the rear suspension over small bumps or when getting out of the car (described as "normal" from the dealer on several occasions.
It appears that there are two different axles used. The first uses a regular rubber bonded bushing that is pushed in and out of the axle. The hole in the bushing where the bolt goes through to mount it to the body bracket is not round, it rather looks like a 3-pronged fan, or a radioactive symbol with the gaps filled in (see http://www.nrc.gov/reading-rm/basic-ref/teachers/radioactive-symbol.html) .
The second type (which I have) has a more conventional bolt hole (steel sleeve in the rubber) and is a hydro-bonded rubber bushing (my terminology here may be somewhat incorrect) which cannot be replaced, and therefore requires the replacement of the whole rear beam-axle (yup - you read it right) and it's over $900Cdn for the axle part) . And we've tried putting the other type of bushing in my axle, but alas it does not fit.
Does anyone know if this is the type fitted only to TDI's? Or possibly to German made cars (which mine is)? Or is this the first anyone has ever heard of something as inane as this?? More importantly. Does anyone know if the first type of axle will bolt up properly, as I may have a used one sourced from a 2002 .
Any comments/questions would be appreciated. I’ll take some pics when I go back tomorrow.
JP
JP
