grampareg
I have only filled mine once and got 53 litres to 1000klm and still had a quarter left
That is about the same as mine. It is possible to recalibrate the odometer, speedometer and fuel calibrations to be within 1%,Overly optimistic MFI
City 15-20%, HWY - 80%.
Distance 632 miles
Diesel - 13.02 gallons
MPG- 48.6
MFI - 52.5 mpg
Optimistic by 8%.
I must be one of the only people with an under reporting MFI. Last tank MFI was 53.4 MPG, actual MPG was 54.3 MPGOverly optimistic MFI
Distance 632 miles
MPG- 48.6
MFI - 52.5 mpg
Optimistic by 8%.
which is what I have done. But I have found different fuels will make a difference in the MFI readings as well.
Yeah, mine has never been under my actual calculated mileage. It's usually about 2MPG optimistic overall.I must be one of the only people with an under reporting MFI. Last tank MFI was 53.4 MPG, actual MPG was 54.3 MPG
You need VCDS, or equivalent, to access the controllers to change the calibrations. I don't remember at the moment what needs to be changed. You will also need a GPS to get a speed reference to calibrate to.How do I get it calibrated. Although, I can mentally calculate 8% off reading.
Very nice!Just hit my first 1000+ tank!
Date 7/29/2014
Miles 1026
Gallons 18.12
Model Year 2013
Transmission 6M
MPG: 56.62 (MFD read 58.9)
A mix of Interstate and back rual roads.
I am surprised you were able to push 18 gallons in there. When does the light come one. How many gallons before the low fuel light comes on?Just hit my first 1000+ tank!
Date 7/29/2014
Miles 1026
Gallons 18.12
Model Year 2013
Transmission 6M
Last Oct I managed to put 18.13 gallons into my tank. My low fuel light comes on with around 3 gallons of fuel remaining. My MFI will read around 85 miles to empty. When I drive my car down to 0 miles to go, I usually have about 1 gallon of fuel remaining. I was down to 5 miles to go the other day and I got 17.70 gallons into the car. The time I put 18.13 gallons in, I went about 15 miles past 0 to go.I am surprised you were able to push 18 gallons in there. When does the light come one. How many gallons before the low fuel light comes on?
That's good info right there.Last Oct I managed to put 18.13 gallons into my tank. My low fuel light comes on with around 3 gallons of fuel remaining. My MFI will read around 85 miles to empty. When I drive my car down to 0 miles to go, I usually have about 1 gallon of fuel remaining. I was down to 5 miles to go the other day and I got 17.70 gallons into the car. The time I put 18.13 gallons in, I went about 15 miles past 0 to go.
Depends upon your definition of city. For example, if you live in downtown Chicago and you go corner to corner and sit in traffic jams...the TDI won't be a great fit.I am thinking about a buying a '15 Passat TDI 6M. I've read many post showing its highway mileage is excellent, but what about 100% city driving?
Once broken in, what mileage could I expect in 100% city (stop and go) traffic?
Look through some of the high MPG owners Fuelly accounts and you will find that 18.6 gallons is about the max that anyone has put in. Of course, this means that there is a little more in the tank because they havent run out of fuel.That's good info right there.
Based on how the needle has moved with miles, I am assuming when it hits the red markings, it'll have 2.5-3 gallons remaining.
I have been re-fuelling way before the low fuel light coming on.
I would expect high 30s to mid 40s. Less in cold weather than in warm weather. The more open roads you do, the better your economy will be.I live in the DC area. 60% of my driving is suburban 45mph two Lane roads with occasional traffic jam stop and go bull$hit and 40% interstate highway.
I LOVE my 6M TDI, but wouldn't get one for 100% stop and go. Get a Prius if your top concern is mileage. Get a gasser golf or similar if you want something fun to drive. The Passat TDI is a true cruiser, built for comfortable highway driving. It handles very well on city streets too and I have no complaints there, but the 6MT isn't a whole lot of fun in stop and go. Partly because it's hard to go slow enough to avoid working the clutch constantly. Partly because the mileage plummets. Based on what you describe, and automatic gasser or hybrid is a better choice. But to each his own.I am thinking about a buying a '15 Passat TDI 6M. I've read many post showing its highway mileage is excellent, but what about 100% city driving?
100% city?I am thinking about a buying a '15 Passat TDI 6M. I've read many post showing its highway mileage is excellent, but what about 100% city driving?
Your statement makes me ask, have you ever driven or owned a diesel auto???100% city?
I would get a Accord Hybrid or wait until Prius redesign (2016?) and get one of those.
If 100% city means slow and you don't drive a lot possibly something small. A mini or fiat 500?
now that is funny......MPG isn't a concern (so much) if you drive 200 miles a month.
But the question might be what do you mean by city. There's a big difference between "I drive in downtown manhattan every day" city and "I live in a town where city driving means I go three minutes at 35MPH, stop, then 5 minutes at 45 with maybe a stop light if I'm catching them wrong" city.
"they had no clue what they were really spending on gasoline in what they were driving before compared to the time they have spent behind the wheel of their fuel sipping VW diesel"
A couple of my friends said they never clocked so many miles without worry of what it was going to cost them in their entire life.....
I do agree with this statement. And chances are, if you are only driving 200 miles per month, you are mostly going to be city, stop and go. Therefore, the TDI will probably not hit anywhere near it's potential as far as high mileage.....MPG isn't a concern (so much) if you drive 200 miles a month.
