Round 1:
- Optilube Summer Tank 1: (1oz added 4/24/13) 616.9 miles; 14.310 gallons added; 43.110 mpg
- Optilube Summer Tank 2: (1oz added 4/29/13) 613.1 miles; 14.164 gallons added; 43.286 mpg
- Optilube Summer+ Tank 1: (2oz added 5/03/13) 604.1 miles; 14.044 gallons added; 43.015 mpg
- Optilube Summer+ Tank 2: (2oz added 5/09/13) 606.0 miles; 13.902 gallons added; 43.591 mpg
- Un-additized Diesel Tank 1: (Pure D2 added 5/15/13) 573.7 miles; 13.806 gallons added; 41.554 mpg
[*]Un-additized Diesel Tank (Outlier): (Pure D2 added 5/21/13) 605.2 miles; 13.638 gallons added; 44.361 mpg- Un-additized Diesel Tank 2: (Pure D2 added 5/24/13) 567.2 miles; 13.990 gallons added; 40.543 mpg
- Optilube XPD Tank 1: (4oz added 5/30/13) 621.9 miles; 13.918 gallons added; 44.683 mpg
- Optilube XPD Tank 2: (4oz added 6/05/13) 609.7 miles; 13.723 gallons added; 44.429 mpg
Round 2:
- Optilube Summer Tank 3: (1oz added 7/10/13) 656.1 miles; 14.726 gallons added; 44.554 mpg
- Optilube Summer Tank 4: (1oz added 7/15/13) 618.3 miles; 14.264 gallons added; 43.347 mpg
- Optilube Summer Tank 5: (1oz added 7/19/13) 603.0 miles; 13.516 gallons added; 44.614 mpg
- Optilube Summer+ Tank 3: (2oz added 7/26/13) 650.0 miles; 14.677 gallons added; 44.287 mpg
- Optilube Summer+ Tank 4: (2oz added 8/02/13) 643.8 miles; 14.257 gallons added; 45.157 mpg
- Optilube Summer+ Tank 5: (2oz added 8/09/13) 600.2 miles; 12.095 gallons added; 49.624 mpg
- Un-additized Diesel Tank 3: (Pure D2 added 8/15/13) 524.0 miles; 13.792 gallons added; 37.993 mpg
- Un-additized Diesel Tank 4: (Pure D2 added 8/27/13) 569.5 miles; 13.796 gallons added; 41.280 mpg
- Un-additized Diesel Tank 5: (Pure D2 added 9/03/13) 586.6 miles; 14.307 gallons added; 41.001 mpg
- Optilube XPD Tank 3: (4oz added 9/08/13) 609.2 miles; 14.173 gallons added; 42.983 mpg
- Optilube XPD Tank 4: (4oz added 9/13/13) 651.4 miles; 14.251 gallons added; 45.709 mpg
- Optilube XPD Tank 5: (4oz added 9/18/13) 679.4 miles; 14.241 gallons added; 47.707 mpg
Round 3 (Double Dose):
- Optilube Summer Tank 1: (2oz added 9/23/13) 628.3 miles; 14.216 gallons added; 44.197 mpg
- Optilube Summer Tank 2: (2oz added 9/30/13) 638.0 miles; 14.438 gallons added; 44.189 mpg
- Optilube Summer+ Tank 1: (4oz added 10/05/13) 618.9 miles; 13.695 gallons added; 45.192 mpg
- Optilube Summer+ Tank 2: (4oz added 10/11/13) 605.8 miles; 13.657 gallons added; 44.358 mpg
- Optilube XPD Tank 1: (8oz added 10/17/13) 624.7 miles; 14.253 gallons added; 43.829 mpg
- Optilube XPD Tank 2: (8oz added 10/24/13) 579.5.7 miles; 14.176 gallons added; 40.879 mpg
Per Fuelly he should be over 56KAlso, post your total miles on the car. TDIs take longer to fully break in, or at least, earlier TDIs. Some here think "break-in" is an antiquated reality, with tighter engineering tolerances.
Still, I'd like to see your total miles in the posts.
Thanks for doing this.
Just about; I am currently at ~55,900 +/- about 10 miles (I don't remember offhand exactly where it was when I parked it, but it's close to that).Per Fuelly he should be over 56K
That was basically my thinking as well; though I figured on testing XPD, Winter formula, and a blend (1/2 winter dose of each, or 4 oz XPD and 2 oz winter). I was also thinking of adding in Power Service white bottle to the testing to see how it comparesNo doubt the cooler temps are causing the mpg to dip, the test I ran in the post below was back to back, same night with & without grille blocks.
http://www.cumminsforum.com/forum/5896337-post168.html
I say if your going to continue testing you should re-establish a baseline w/o additives then start over with the XPD tests...
On the ram I used to see about a 1 mpg bump during the summer. IIRC 16 oz to 34 gallons of diesel. No real testing of any kind back then, just tank to tank averages.That was basically my thinking as well; though I figured on testing XPD, Winter formula, and a blend (1/2 winter dose of each, or 4 oz XPD and 2 oz winter). I was also thinking of adding in Power Service white bottle to the testing to see how it compares
Thoughts/ideas?
Been following this thread since the beginning, very cool and thanks for sharing the experiment. I wouldn't mind seeing what your findings are with the Power Service white bottle added to your test, actually would be very interested.That was basically my thinking as well; though I figured on testing XPD, Winter formula, and a blend (1/2 winter dose of each, or 4 oz XPD and 2 oz winter). I was also thinking of adding in Power Service white bottle to the testing to see how it compares
Thoughts/ideas?
Someone has to keep Opti-Lube in business.......Question 1: Why? You are "creating" almost nothing more than a blended version of XPD for approximately triple the cost...
Question 2: How much of that blend are you putting in each tank? 1oz of XL and 1oz of Boost! are plenty to provide solid results based on testing. If you are putting all of that in each tank then I only have one word for you...
STOP
LOLOL....Someone has to keep Opti-Lube in business.......
