RCD330 Faults
Jedadiah
Central Kentucky
'15 Passat TDI SE 6M, Former: '15 Golf and '10 JSW
If it's looking for modules that are no longer on the car, you can uncheck the modules from the CAN Gateway list. I've used VCDS to install new modules this way. I assume OBDeleven has the same functionality.
CleverUserName
NorCal
2014 OZ Cruze CTD & 2010 JSW 6MT
Would these faults cause issues with CarPlay or AA ?
My mom has an RCD330 in her Jetta and we could not get the APPS to work. It has these faults:
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 541 5614
Revision: -------- Serial number: VWZZZ4R6218291
Coding: 16000400040005
Shop #: WSC 00078 790 00217
VCID: 4683BDE0F1B5FABBB9-8012
5 Faults Found:
00849 - S-contact at Ignition/Starter Switch (D)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 67
Reset counter: 86
Mileage: 0 km
Time Indication: 0
00856 - Radio Antenna
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00111011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 112
Mileage: 0 km
Time Indication: 0
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 248
Mileage: 151665 km
Time Indication: 0
Date: 2000.00.00
Time: 22:58:26
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 248
Mileage: 151665 km
Time Indication: 0
Date: 2000.00.00
Time: 22:58:26
02873 - Control Module for Back-Up Camera (J772)
Freeze Frame:
Fault Status: 00110100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 248
Mileage: 151665 km
Time Indication: 0
Date: 2000.00.00
Time: 23:20:09
End-------------------------(Elapsed Time: 04:33)--------------------------
