Rawtek 2014 jetta
claws413
Usa
2014 jetta
Can any of you confirm if rawtek may have accidentally sent the wrong downpipe. Pics attached, there is no egt threading. Does the 2014 model not need this sensor, or is it just a accident on the side of the vendor?
The receipt was double checked and confirmed that the correct kit was ordered.
If you need any clarification, I'll respond when available.
Last one I, er.... "a friend", did, which was on a CKRA, did not have that EGT sensor hole either. But the car/new tune had no issue with it being gone. I thought it was a CKRA thing, because the CJAA ones usually do, but maybe they decided they could just do away with this redundant sensor... as there is already an EGT sensor literally two inches away in the turbocharger itself.
The lambda sensor hole was still present, though.
claws413
Usa
2014 jetta
So should Installation be attempted? As in, will there be any damage to the engine without that sensor?
Also, what are the odds of a warranty/exchange issue if it is installed and found to not work with the vehicle. (If you were to speculate).
The sensor is a function of the what the tune uses. If the two answers you've already been given still do not satisfy you, contact the tuner and ask them.
AverageAndy
Phoenix, AZ
2013 Passat TDI SEL, 2013 Golf TDI 6MT, 2013 Jetta TDI 6MT (R.I.P.)
My non-rawtek pipe did not have the extra EGT hole either. 2011 CJAA Sportwagen.
Same with the one I had from Flowdirekt -only had bung for oxygen sensor (this was on CJAA).
If you look at MecEvo, Profidiesel, and probably other downpipes, they only use the lambda sensor as well.
claws413
Usa
2014 jetta
Did you do a tunezilla tune with that setup?
Petra's cousin
Calgary
Mk VI TDI Golf Wagon
I did wonder about the missing EGT bung since I was following the Rawtek instructions. But, like Oilhammer says, there is one in the turbo and I don’t think I could have extracted it from the DPF piping anyways. If concerned, check with your tuner if it’s needed (I may have messaged Malone, but don’t exactly remember).
gmcjetpilot
Memphis TN
2010 JSW TDI DSG Matalic Grey
Thanks for the insight! You've been super knowledgeable!
It is NOT needed. Why VW put two in I do not know?
At one time Rawtech thought they needed two Turbo Outlet EGT's bungs. They do not. The tuners don't use it.
Last you have a TURBO inlet EGT in the turbo housing you can see from above.
